Does anyone know where I can get the wiring from the starter solenoid,to the alternator,and voltage regulator??
It comes out as one small section. I think mine is bad now because I have a new voltage regulator, alternator and battery yet it wont hold a charge.
Im pretty sure some of this wiriing is bad.
Alternator harness
re: Alternator harness
That's something you'll have to get from a donor truck, either from a salvage yard or maybe someone here on the forums with a parts truck. You'll need to make sure the piece you get comes from a truck with the same style of instrument panel you have (idiot lights or gauges), since the two styles of instrument panels each use a different harness. The harness for a truck with gauges has a shunt used to supply power to the ammeter.
So what have you done as far as troubleshooting goes? How did you determine that this harness is bad?
I got dibs on the first 4gauge alternator harness... already posted it in the Wanted section.
Patrick
Patrick
Chevrolet
Can Hear Every Valve Rattle on Long Extended Trips
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
http://www.fordification.com/galleries/ ... ?cat=10336
well I took it to a shop and they told me that my wiring that goes to the voltage regulator is broken somewhere.because power isnt getting to the regulator therefor it wont charge.
Well, while you're looking for a replacement harness, it wouldn't hurt to use a multimeter to run continuity checks on the wires in your existing harness. You should be able to find the break and repair it easily enough.
- 67highboy
Check with green70 i think he has one he is parting
People who are willing to give up essential liberty to purchase temporary safety, deserve neither liberty or safety...
Ben Franklin 1775
Ben Franklin 1775
how do I find green 70?
- Mohillbilly
Green70 has been on within the last 24 hours. If you click on 'Visit the FORDification Forums", and scroll to the bottom of the screen. There it lists evryone who's been on in the last 24, so just click on Green70's name, them PM (Personal Message) him from his profile. It will come through to him the next time he logs in.
70 Custom LWB, 302-2V, 3 on tree
