I can't figure out why i'm getting no spark, it's a '75 electronic ignition, motor turns over but won't fire, i'm getting fuel, i have compression, timing is set (or reasonably close) truck has new battery, starter relay, starter, alternator, voltage regulator, ignition control module, coil, distibuter, ignition switch, cap, rotor, plugs and wires, and still NO SPARK!
I've exhausted all my (very limited) electrical knowledge and don't know where else to look, with all new electrical componets installed i'm thinking my problem lies somewhere in the wiring itself? i just don't know, any suggestions would be greatly appreciated, i hate to take it into the shop at $65 an hour labor rates if it's something i can fix myself, Thanks.
NO SPARK!
- Redcap
re: NO SPARK!
Did you have this truck running on old parts? I wonder if all the new stuff isn't the source of the problem.
- splavin90
re: NO SPARK!
i've got an 81 duraspark ignition in my engine. maybe i'll be able to shine some light on this thread.
duraspark electronic ignition
http://users3.ev1.net/~bmarr/57bcfe50.png
make sure there's 12V on the red wire on your igniton module.
it should read ~12v while the key is in start and run
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
re: NO SPARK!
it was a bad ballast resistor
- theskytoucher
re: NO SPARK!
at least you got it figured out with no shop visit
-Troy-
1996 Dodge ram 1500 4x4
1976 Ford F-150 4x4
Quando Omni Flunkus Mortadi
When all else Fails Play Dead
1976 Ford F-150 4x4
re: NO SPARK!
they say man's best friend is a dog, but i'd say man's best friend is a $15 volt/ohmeter
