Fuse Panel
Fuse Panel
Has anyone used an aftermarket fuse panel in conjuction with the main fuse panel? Reason asking, i am watching "Two-guys Garage" on TV and they had a old truck that had more wiring than fuses. He mention a aftermarket 8-fuse panel. You have a hot wire and one wire for ignition and then 7 fuses for up to 20 amps for install accessories on a vehicle. About how much would those run? I am thinking it would be good for my upgraded stereo, air horns, LED lights, driving lights and such...
- adrianspeeder
re: Fuse Panel
10bucks at napa.
Adrianspeeder
Adrianspeeder
'08 F-250 Spartan Tuned 6.4L PSD ZF-6 4x2 XL, Reg Cab,
'02 F-250 Vin Diesel 7.3L PSD 4R100 4x4 XLT, Crew Cab,
'97 F-150 Dad’s last truck 4.6L M5OD 4x4 XLT, EX Cab,
'79 F-150 Homebrew Dually 351M C6 4x2 Lariat, Reg Cab,
'71 F-100 Bump 302 4x2 3/tree Stepside Custom, Reg Cab,
'66 F-250 Slick 352FE 4x2 3/tree Custom Cab, Reg Cab,
Broncos: '94 Grandpa’s mint daily driver XLT 302 E4OD,
'92 Momma’s daily driver XLT 302 M5OD, '88 OJ XLT 351 C6, '84 Mint! Lariat 351HO C6,
USAF TSgt C-17 Aircraft Maintenance Flying Crew Chief & Flightline Avionics Craftsman
re: Fuse Panel
Thanks adrianspeeder, that's what I am look for.
- adrianspeeder
re: Fuse Panel
Thanky.
If'n yer orderin' online, heres the part numbers for the fuse panel, relay harness, and relay...
Adrianspeeder
Adrianspeeder
re: Fuse Panel
so, what did you plug into the fuse panel on yours?
re: Fuse Panel
Wiring mine in in place of the original ones. My panel 10 port cost me with my account at Napa 28.88. PN# BK 7823212
The panel can hold 10 20A fuses so I am putting my Black Yellow wire to it and then pulling everything else off of it.
re: Fuse Panel
so, no problem with water hitting it, being mounted on under the hood outside?
re: Fuse Panel
ok, now i got another question, i see that AutoZone has a 12 circuit fuse block that can possibably replace my existing one and upgrade it. Has anyone done that or would I be spinning my wheels on this and should either redo the whole thing or just get a 8 or 10 circuit add-on for my accessories to add to the truck?
Darn those are pricey. That 12 circuit is nice if you are rebuilding a harness from scratch. The picture is misleading the fuses and the flashers don't come with it I have seen it in the store.
The model that I just bought and that adrianspeeder turned me on too is much simpler and comes in 4/8/10/12 sizes.
The ten that I bought listed for 41.66.
- adrianspeeder
re: Fuse Panel
41! Cheeze and crackers. I thought it was 10 or twelve when I got it for the '88 last winter break from school. Course I did buy 300bucks worth of other electrical so it mighta been discounted.
Anyway, actually finished up my wiring today on the '88. Everything is crimped, soldered, and heat shrunk. Any bit of water that manages to get up in there shouldn't be a problem.
1. CB radio
2. Auxiliary reverse light power
3. Air Horn compressor power
4. Air Horn relay
5. HVAC blower (stock wiring melted for some yet unknown reason)
6. 12v power point's in the dash
7. Low beam power
9. High beam power
Adrianspeeder
1. CB radio
4. Air Horn relay
7. Low beam power
9. High beam power
Adrianspeeder
You can pick up 12 ciruit painless fuse blocks on ebay for between 30-60 bucks.. Just have to keep an eye out.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... Track=true
I have one that I want to use to replace/upgrade the existing fuse block. If I ever start it I'll take pictures and do a write up.
Patrick
Patrick
Chevrolet
Can Hear Every Valve Rattle on Long Extended Trips
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
http://www.fordification.com/galleries/ ... ?cat=10336
