#13 - Aug. 4, 2007
- Manny
re: #13 - Aug. 4, 2007
Man i so knew that one guess i should've got here quicker i guess.....
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- kaptnkaos
Thanks Guys...
I have removed nearly every nut and bolt off of a bump except the timing cover... never need to.
I got my '68 CS with 1200 miles on a fresh HP 390... the only major mechanical work I have had to do on the engine is replace a blown head gasket. I will have had it for 20 years in Oct and will have put 60,000 miles on it.
At that rate, I figure that I'll drivin' a Bump in heaven a long time before it needs to be rebuilt again...
KaptnKAOS
KaptnKAOS
Washington...The land where rust is like the family pet...Ya learn to live with it and clean up after its mess... KaptnKAOS
"Olde Skool" '68 Ford Bluebird short bus
"FRODO" '68 F-250 Camper Special project
- Manny
Yeah fe's seem to just run like the energizer bunny.
- rjewkes
the little 302's seem to be that way too. also the 240 sixes seem to run like a top for ever.
