Moulding Measurements
does 3 7/8 sound like the correct measurement for the rocker mouldings on the rangers?
'69 Calif Ranger in PA, 2001 GMC Sierra SL 4x4
Liar, Lawyer, Mirror show me, Whats the difference?
re: Moulding Measurements
It's closer to 4", I believe. I've got all the trim measurements posted at http://www.fordification.com/trim.htm
Thanks Keith, I actually forgot about your section on trim. I found what I thought was the correct piece of trim at KAMA Obsolete. They state that the D0TZ... part (an abviously 70++ year number) was the tool box trim that measured 3 7/8. You list D0TZ as the 1 3/4 narrow trim for 70-72 while C7TZ is for 67-69. All that is correct. I have the C7TZ wide trim on my Ranger and it is tweaked badly from a minor accident before I bought the truck. On the way home from work I took the trim off and measured it and it was 2 7/8 approximately, so we'll say 2 3/4. These are very hard parts to come by and I wrote back to KAMA to confirm what piece it actually is. I am hoping they made an error in the part # and it is the part I need and not the narrow trim.
One thing is for sure, it certainly makes doing a proper factory restoration quite a challenge. Then again what fun would it be if the parts could be had at your local NAPA for a dime a dozen!!!
later-- Jeff
later-- Jeff
