my i-beam/drop bracket project
boots
Post by boots »
well one of my friends came over to help me with this project to get my camber correct on my 67 f100 because i put some 4" lift coils on my truck. so that means i have to build drop brackets for my i-beams so my tires sit straight. bending was not an option, the only person that could do it said $575.00 to do it, and new lift beams cost around that much too. So here are the layouts of the drop brackets. Now I have to buy the materials and cut these brackets out..... ( Just so no one get confused ) If you look at the 1st image link you will see that the top is welded to the frame, and the whole at the bottom is were the i-beam bolts on to. There are a few other things we are doing, such as putting a spacer in between were the i-beam use to bolt onto so that its not weak at that point.
here are the pictures that my friend designed:
http://img.photobucket.com/albums/v629/ ... acket1.jpg
http://img.photobucket.com/albums/v629/ ... acket2.jpg
http://img.photobucket.com/albums/v629/ ... layout.jpg
should be finished soon , ill keep everyone posted incase anyone is planning to do this to there truck. what you guys think?
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
Heavenlyfire
re: my i-beam/drop bracket project
Post by Heavenlyfire »
your doing yours the easy way :P . Let me know how it goes, mine is ify
mrung0wa
Post by mrung0wa »
That is the way I would prefer to do mine too!
I'll bet there's a lot of other Fordification brothers wanting the same!
Good luck and take a bunch of photos!
Lman
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
boots
Post by boots »
took a pic of a peices that I got yesterday after being laser cut. here is a picture of what will make 1 of the 2 brackets.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
