Impact wrench suggestions?
Discuss your workshop and related equipment
basketcase0302
re: Impact wrench suggestions?
Post by basketcase0302 »
Robert,
I believe...our wheel lugs are torqued to about 75 ft. lbs.
Both of those should work with no problem, (and a sufficient supply of air pressure).
Yes, you should be looking at IR! Not sure in the difference in the two models though.
My nuke sub had a two IR 4 stage compressors that lived to be dinosaurs. :thup:
IR is good stuff IMO.
BobbyFord
Post by BobbyFord »
I've got several, Ingersoll, Snap-On, Mac, etc...
The Ingersoll and the Snap-On work very well. If you get the Ingersoll, get the one with the steel nose housing. Snap-On air tools are expensive but work well. Another advantage of Snap-On air tools is that if it breaks outside of the warranty period, it's $75 to fix, no matter what's wrong with it.
xxxtina63
Post by xxxtina63 »
BobbyFord wrote:I've got several, Ingersoll, Snap-On, Mac, etc...
By a steel nose housing, that's vs aluminum or cast iron?
BobbyFord
Post by BobbyFord »
Vs. aluminum.
72stepside
Post by 72stepside »
This one...
http://www.sears.com/shc/s/p_10153_1260 ... act+wrench
has yet to meet a bolt it wouldn't move. I'm very happy with the purchase. I used it with my homemade rear spring bushing puller with no problem.
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
