My 72 Sport Custom F100 (Shes alive!) 10-21-2010
- MaxKlinger
re: My 72 Sport Custom F100 (updae 8-09-08)
Just figure that the compression ratio for a 460 in a Lincoln in 1975 was probably between low and crap.
Tony
'72 F100 LWB 2WD Custom, 360FE, T18
'05 Focus ZX4 ST - 2.3L, 5spd
'83 F150 LWB 2WD, 300-I6, C6 scrapped 2006
- OldRedFord
Re: re: My 72 Sport Custom F100 (updae 8-09-08)
Same heads as the 84' 460 tho. Duno what the pistons look like yet.MaxKlinger wrote:Just figure that the compression ratio for a 460 in a Lincoln in 1975 was probably between low and crap.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- OldRedFord
Got the block cleand up and painted.
Heres some pictures,
Tim
- HRDROKN
re: My 72 Sport Custom F100 (updae 8-21-08)
Project is looking good!
'69 Ford Cummins Crew Cab... Built 6BT main & head studs, ported & oringed head, springs, Ti retainers, marine cam, tweaked P7100, 4K gov kit, NV4500 w/1.375" input, Southbend 3600# DD clutch, NP271 w/SYE, D60 HP front, high steer, 16" coilovers & 4-link, D80 w/disc rear, 4.10's & LSD, spinning 38" x 14.fiddy's on classic slots..... more coming!
http://www.fordification.com/forum/view ... hp?t=23267
- OldRedFord
- OldRedFord
Crank, pistons, new rings, new cam, new bearings installed over the weekend.
The cam I picked out is a Crane Cam # 354551.
522 intake lift with 288 duration
530 exhaust lift with 292 duration
Im hoping this cam will have some lope at idle.
Will be coating the cylinders down with Lubriplate cause it looks like I have to stall this project for a while.
Tim
- dablack00
Ok:
1. You ordered stock size pistons?
2. Did you check the taper on the bore?
3. What pistons did you buy?
4. What compression ratio will you end up with? Those D3's have big chambers....ask me how I know.
5. What will you do to your D3 heads to allow that high of a lift?
6. What intake are you using?
7. Have you ported heads before?
I'm not giving you a hard time at all. Just trying to make sure you end up with what you want.
- OldRedFord
Re: re: My 72 Sport Custom F100 (updae 8-21-08)
1. Used the stock ones. Long storydablack00 wrote:Ok:
2. Took one of the new rings and checked end gap at different points in the cylinder.
4. Stock
5. Going with the valve springs that Crane recommends.
6. Edelbrock Performer RPM or a Weiand Stealth, with a Holly 750 cfm carb
7. No I haven't, tho I have a 2nd pair of D3's layin around.
No problems man, Im just learning as I have been going here. First time building a engine for performance, much less a 460.
Tim
- OldRedFord
Engines current state
Tim
- BobbyFord
Nodular center section, larger diameter backing plate studs, no taper on the end of the axle housing near the backing plate flange, the shape of the flange where the backing plate bolts (not rounded on the bottom). Also, most 28 spline axles do not have the two dots in the end of the axle flange and I've never seen a nodular center section with 28 spline axles.crazyhorse wrote:BobbyFord wrote:...big bearing, 31 spline, too.[/quote] how can you tell if it is a 31 spline just by looking at the rear end & not pulling the axles ? just wanted to know before i go to the junk yard. thanksBobbyFord wrote:That "crusty old 9" has a nodular pumpkin...
- OldRedFord
re: My 72 Sport Custom F100 (updae)
So Monday I got the other engine block back from the machine shop. So far I havent been able to sell it.
Its bored out enough that I could build a 521 stroker.
I wish I had a job now....
Stay tuned....
Stay tuned....
Tim
- OldRedFord
Re: My 72 Sport Custom F100 (updae)
Today I installed a double roller timing set.
Tim
- OldRedFord
Today (Saturday) I received power steering brackets and a pulley from Hawkrod. Will be prepping all the brackets and pulleys for paint tomorrow.
Tim
