want to get some pics of a F250 leaf front 4x4 set up... debating on getting front stock hangers to bolt on my 2wd F350 to convert to 4wd...
Thanx,
Todd
need pics of F250 leaf 4x4 front
- zakt
1972 Ford F350 crewcab
Re: need pics of F250 leaf 4x4 front
might be able to help you out what exatly you looking for?
- zakt
Im looking for a bunch of pics of the front leaf hangers (mounting locations), steering box location (steering shaft, pitman arm, tie rod, drag link etc) motor mounts, front cross member.
Thanx,
Todd
Thanx,
Todd
- averagef250
Todd, not sure if it's still there, but there was a thread I started in the buildup section about switching a 78 F-350 crew to a 4x4 and installing a Cummins. There were a few good shots of how I made the engine stands and crossmember.
If you have access to a highboy frame I would splice the highboy frame into the crew 2wd frame under the cab. It would be far cleaner than making all your own frame parts.
Look at it like this- to convert the front of your frame to a highboy setup you are going to pull the whole drivetrain, completely remove every crossmember and bracket off the front frame rails and modify/build a ton of stuff to make it work. Way, way easier to just have the 2 frames side by side, do some real careful measuring, make 4 cuts and 2 nice welds where nobody will see them. Put the 2wd body back on with a 4x4 steering column and drop your engine in with a 4x4 tranny and mated t-case.
- RedneckTexan
Good stuff to know!
Dustin, here's the link to the page yer talkin bout!
http://www.fordification.com/forum/view ... 22&t=27064
