Has anybody tried to open up the holes on the newer (97 - up) Ford aluminum F150 wheels to make it for the 5X5.5 pattern. Looks like it could be done with a file or one more notch on a Uni-bit.
Should I? Will it kill me?
New Ford wheels on an old Ford truck
- Bobaloo2
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
re: New Ford wheels on an old Ford truck
Basically you'll be making them like the old unilug wheels they sold to fit a Ford or a Chevy (they had elongated holes)? The front mags that were on my '65 Stang were like that and they never fell off.
If the back of the wheel is solid in the lug area and you used hardened washers under the heads of the lugs, to spread the load it'd probably work.
Disclaimer: Try at your own risk
1969 F100 Ranger LWB Big Block, factory bucket seats and behind seat storage (arrived 3/21/12) (and it was free!)
1986 Thunderbird Turbo Coupe 247K and still going strong! (sold with 251,758 miles on it!)
1986 Comp Prep SVO Mustang (1 of 83) "the original Fox body "R" model!!"
1972 Ford F-100 LWB SOLD 5/2/6
1995 F150 XLT Supercab (wanna trade for a Bump?)
Oh yeah if the wheels won't be hub centering, you'll want to set them up in a mill and elongate the holes as the bolt pattern will be centering your wheels and will have to be accurate. Unless you like the wheels to be mounted off center so it'll look like one of those clown cars going down the road........
- Bobaloo2
I'm sure my grand kids would love it, but I better stay away from making the truck any funnier looking than it is. The peeling silver spray bomb paint job is enough....
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
- Bobaloo2
It appears the difference is 4.7 mm. The newer wheels are 5 X 135mm,
the 5 X 5.5 works out to be 139.7mm. That close. Anybody else tried this, please post. Thanks
Bobaloo2
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
Bob Mayben
1967 F 100 SWB
1963 Bel Air 409
