same bellhousing?
same bellhousing?
I have a 76 F100 with a 360 and C6 automatic transmission, which I am considering putting into my new 72. The 72 has a 302 with a 3 speed manual. I dont think they have the same bellhousing and are therefore not interchangable, but my dad thinks they are the same.......Who's right?
re: same bellhousing?
It's an option, but I'd like to save on fuel wherever i can. I'm just using this as a work truck to bring stuff home from home depot and trips to the dump and stuff like that. Gas is $1.03 per liter here, which works out to over $4.00 a gallon! I think I'm just going to keep the manual tranny with 302 in there if I can get the shifter linkages to work a little smoother. I find it fun with the three on the tree!
- 1970F250
- 72hiboy4x4
but the C6 robs you of about 10% of your HP thru slippage in the torque converter. I believe a manual tranny driven correctly will save fuel.
In life many men take the path of righteousness, some take the path many others follow (G.M. owners, for example), some take a more arduous path, some a simpler path. I, sir, took the PSYCO-PATH!!
- 1970F250
i didnt think of that
i was thinking how much i would be reving a truck with a manual tranny and all the gas it sucks at high rpms. i agree with you now.
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
