35 INCH TIRES
- 1970F250
35 INCH TIRES
will 35 inch tall tires fit on the front of a 2x4 1970 f250 with 4 inch lift?the only problem that i cans see is that they might rub on the frame when i turn. anyone know first hand?
Steve
binder56jd wrote: If you can't dazzle them with diamonds- baffle them with b------t
- 72hiboy4x4
re: 35 INCH TIRES
They will fit, but will rub if you articulate the truck to much or add to much weight in the back. Take it to a tire shop and have them do a test fit. As far as frame rub you should be just fine.
I run 33". I can't run 35" because I haul wood with it.
- 460 crew
re: 35 INCH TIRES
I have a skyjacker 4in lift and run 35's and they have rubbed the fenders every time I go offroading. Then again I'm not easy on it. On a 2wd stock you can fit 31's so with a 4in lift I'd say easily 33's and 35's if it was staying primarily on the road but might rub offroad on some of your body when turning and compressed. You could also call up Autofab in California the guy there is way cool and I'm sure he'd tell you exactly what you'd need for lift to fit what you want under your truck and be functional.
- 72hiboy4x4
re: 35 INCH TIRES
My mees-take! sorry greg
re: 35 INCH TIRES
a guy at my work runs a highboy with 35's but he has massive stabilizer bars and never off roads it
68 f250 "highboy" frame
67 np435 trans
68 dana 24 t case
67 dana 60 rear w/track loc
76 dana 44.6cf front w/DPC and heavy duty hubs
70 ford body w/rust incuded!!!
R.I.P. the 87 subaru GL wagon "the traildancer"
67 np435 trans
68 dana 24 t case
- 1970F250
re: 35 INCH TIRES
Thanks guys
im going to try for 35"S
Steve
- 460 crew
So TRMMULLET your saying he has a queen pavement pounder?LOL
re: 35 INCH TIRES
Buy a cordless sawzall and carry it with you. Just whack off anything that rubs the tires.
- 460 crew
Autofab has fiberglass fenders that have larger wheel openings here.. take a look. http://www.autofab.com/DSC00006.jpg
