Old Shocks
bwc302
Old Shocks
Post by bwc302 »
Pulling the front suspension off a donor truck and having a good time with some shocks.
When attempting to take off or loosen the top nut, what is a good way to keep the shaft from spinning?
Thanks,
Bobby
If you don't care about reusing them just clamp a pair of vice grips on the shaft.
Most of them have a flat or allen key head on the top as well, but vice grips works better if you aren't trying to reuse.
I just put KYB's on the front of mine and they made a huge diffrence
Fordfool
re: Old Shocks
Post by Fordfool »
Smoke wrench works best :D
My Gallery
"Knowing is not enough, we must apply,willing is not enough, we must do" -Goethe
FORDification
Site & Forum Admin
Site & Forum Admin
re: Old Shocks
Post by FORDification »
I've always used Vice Grips as well. The end of the shaft will accept a special tool that will hold it while you're loosening the nut, but I've never bothered with getting one.
bwc302
re: Old Shocks
Post by bwc302 »
So just clamp the vice grips above the nut toward the top of the shaft?
Thanks,
Bobby
FORDification
Site & Forum Admin
Site & Forum Admin
re: Old Shocks
Yeah, at the very tip of the shaft....away from the threads. If the shocks you're removing are throw-aways, and the threads are rusty/stripped, just remove the nut enough to get a cut-off tool under it and cut the shaft. It'll save you some grief.
flyboy2610
re: Old Shocks
Post by flyboy2610 »
A grinder will work well, too, if you have room for it.
Re: re: Old Shocks
bwc302 wrote:So just clamp the vice grips above the nut toward the top of the shaft?
I clamp it down low below the mount. If the shock has a metal dust shield made on, use a channel locks or a strap wrench on that.
bwc302
re: Old Shocks
Post by bwc302 »
Thanks all, I will probably replace them but just to be sure I will vice grip the tops.
Bobby
