power steering pump busted
re: power steering pump busted
yeah I've only found return lines for either the 302 or just the ford gear
69 F-100 2wd 360 cid C6
Catapultam habeo. Nisi pecuniam omnem mihi dabis, ad caput tuum saxum immane mittam.
I have a catapult. Give me all the money, or I will fling an enormous rock at your head
no one? I found a hose listed for a 360 but is for 70-72 models, then again it might fit a late 69...not sure about when my was made
....febuary 12th 1969 not too late...
As mentioned earlier, I think almost every auto parts store I've ever been in will fabricate hydraulic hoses for you on-site. Just bring them the old one and they can duplicate it and save you a lot of time looking for one that's been obsolete for 35+ years.
Fordification is right, take the hose to a hydrulic shop or an auto store that can fab hoses. I think it cost me $30 to have my hose built for my P.S.
Yeah, probably right. I just trust molds to be right each time better than human hands.
The return hose is low pressure. You can make any length of steering hose work with just hose clamps. Maybe even fuel line.
i'm counting my options here and found a 68 bendix in mac's I shudder at the thought of dealing with their service line though, so: as I understand it all bendix boxes have 4 bolt connections to the body/frame and are all the same through all years that they were used. correct? if that will not work i'll be looking for a steering column too...
thanks
thanks
NPD list quite a few PS hoses. They were the only ones who had decent quality hoses for my 72. Although nearly any NAPA can make hoses...
by engine tower you mean that thing the box seems to be suspended from?
Engine tower is the stand the engine mount bolts too.
See:
http://www.fordification.com/powersteering.htm
See:
- lobuck76
You need to save the fitting off of your old low pressure side hose. Also the fittings and their location are pretty much the same for the bendix and saginaw box. I just swapped from one gearbox to the other on my '71 and the hoses worked fine. The high pressure side should be pretty much the same up through 1970something. Pretty sure they used the same style pump for several years. The parts house guys will pull parts for a few different year models for you to look at if you ask them.
For instance ask them to show you both hoses for a 1976 model with a 302. They would probabley work on your truck. The low pressure side might be a different length because of the different cooler.
'71 F-100
- 68F250
Guys, check out this thread.
http://fordification.com/forum/viewtopic.php?t=2139
I seem to remember something about the different pressure for the Bendix steering box. Something like if you use a later pump you'll blow out the seals on the bendix box or is it the other way around? Sorry, the memory is foggy.
Barry
Re: re: power steering pump busted
Yeah didn't someone post the tag numbers he needed for a resto with a Bendix?68F250 wrote:Guys, check out this thread.
my head hurts
- 67effie
Return lines are non pressurized so if you have the fitting that goes into the box you can use some regular hose for the return. I did mine this way and have had no problems with it at all. I do have some pics of it in my gallery if you want to look.
If at first you don't succeed. Get another beer.
Jeremy
1972 F-100 - currently under going complete frame off restoration
1997 Mustang GT Convertible- (gone but not forgotten, damn unemployment)
1996 Saleen S281 #247
1988 - Coupe, OSP car sold to public NEW, under construction, 1 of 3 that was supposed to go to Saleen in 1988.
http://www.fordification.com/galleries/ ... ?album=270
Jeremy
