My 72 Sport Custom F100 (Shes alive!) 10-21-2010
1971ford
Re: My 72 Sport Custom F100 (updae)
Post by 1971ford »
Oooo exciting!
I'm going to the junkyard Friday. I'll grab you a set of brackets.
-Ryan
OldRedFord
Post by OldRedFord »
Block is back from the machine shop. Friday I drove down
to Summit and got a
Timing set
Oil pump
Oil pump screen
Solid lifter and adjustable pushrod for checking rocker arm geometry.
ATSG book on rebuilding a C6.
Next on the purchase list..
Gasket set, valve springs, kickdown and shift arms for the C6.
Hoping to get a radiator for my birthday. (the 27th)
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
BobbyFord
Post by BobbyFord »
Sweet!
OldRedFord
Got the gasket set and valve springs a few days back.
The valve springs are http://www.summitracing.com/parts/FMS-M-6513-A50/
Cleaned up one of the heads, and painted it.
Also got the brake booster brackets from Ryan (1971Ford)
Tim
OldRedFord
Pics
Before cleaning and paint...head is covered in lithium grease to keep rust at bay.
After clean up and paint
Trying my hand at some port work.
Tim
OldRedFord
Re: My 72 Sport Custom F100 (updae 2-9-2010)
So today I put the valves back in, and installed the new springs and valve stem seals.
Now for more pics.
Finished, still need to clean the rocker arms up tho.
Valve cover plans
Currently my valve covers look like this
I plan to paint them the same blue as the heads, and then paint the lettering and box red or black.
I am not sure if the 429/460 valve covers ever had this style script but I like it better
Tim
OldRedFord
I neglected to post a few weeks back about getting the interior somewhat back together.
Heres some pics of that.
Quick and dirty temporary floor patches from flashing and sheetmetal screws, sealed with caulk.
Tim
BobbyFord
Post by BobbyFord »
The heads look good. It's nice to have engine goodies with a fresh coat of paint :D
cheek
Post by cheek »
Lookin good Tim! I wish my seat was in such good condition! :(
1970 Ford F100 351C FMX Daily
1972/3 Ford F100 Project
basketcase0302
Post by basketcase0302 »
Looking good Tim! :thup:
What are you doing for exhaust? What ever you do I bet that BB will sound nice!
OldRedFord
basketcase0302 wrote:Looking good Tim! :thup:
I have a set of headers to go on that will feed into 2 1/5" pipe with a H-pipe feeding into two of these http://www.summitracing.com/parts/MPE-10416/
8)
Another update..
Cleaning up the intake manifold. I used a Scotchbrite pad and some PB blaster on one side. The pics are of each side, but you get the idea of the before and after.
Tim
BobbyFord
Post by BobbyFord »
8)
Those are going to sound nice!
OldRedFord
Worked on the intake manifold today. I got a little over confident and didnt mask off the intake gasket surfaces. :oops:
Tim
OldRedFord
Re: My 72 Sport Custom F100 (updae 2-10-2010)
Just have been messing around with the screw in water jacket plugs for now.
After that is squared away it is on to the other cylinder head and start putting it all together.
Only hold up right now is the shift arm I need for the transmission.
Maybe around mid March Ill have it in the truck!
Tim
OldRedFord
Today I started on the other head. The pics are of it with the peliminary cleaning done. Head is stripped bare except for the ground strap. Chased all the bolt holes.
The to do list for this head...
Lap valves
Grind smog bumps down
Install new valve springs and stem seals.
Paint
Tim
