Step on the Scale?
- 68muscletruck
Step on the Scale?
Anyone have a ballpark number for what a 67-69 LWB F100 might weigh?
- 68muscletruck
Re: Step on the Scale?
alright so roughly 4000... thats actually not that much!
once you start taking the truck apart you kind of wonder where all the weight is at. probably in the 390. the heavy pig.
- 68muscletruck
haha its certainly not in the gas tank these days with prices going up
someone would do good to make aftermarket fenders and hoods from aluminum for those of us who have the heart of a muscle car in a truck's body... and so my name, Muscletruck was born
- 68muscletruck
dang that would defeat not only the bank account but the new cosmetic scheme of my truck! maybe i'll just blow the thing and cut a huge chunk of the old steel hood out
they're actually not that heavy, just piece by piece it adds up
- fireguywtc
My 67 f250 weighed on the scale 4250 with aluminum wheels.
Bill
1967 F-250 LWB 2WD 352 V8, 4spd manual, true duals, 122k original miles (currently being restored)
2024 F350 CCSB, darkened bronze
A 351 windsor weighs 525lbs and a 390 weighs 625lbs, replace the 80lb intake with aluminum intake and the 390 will only weigh 25lbs more than a windsorfordman wrote:once you start taking the truck apart you kind of wonder where all the weight is at. probably in the 390. the heavy pig.
So an aluminum intake only weighs 5 pounds???hazelnut wrote:A 351 windsor weighs 525lbs and a 390 weighs 625lbs, replace the 80lb intake with aluminum intake and the 390 will only weigh 25lbs more than a windsorfordman wrote:once you start taking the truck apart you kind of wonder where all the weight is at. probably in the 390. the heavy pig.
- 68muscletruck
ya not to mention an FE intake is pretty much the widest intake you'll ever see for a light truck big block... I held my old Performer 390 from Edelbrock and a cast intake from a SBC that was half the size, I could walk around with the Edelbrock all day and not get tired, that cast intake even just half the size was so much heavier i couldn't even believe, I can only imagine what the difference in the heads is like
- Doug F
68muscletruck wrote:I can only imagine what the difference in the heads is like
I would guess the FE heads would be a little bit lighter, since part of the "head" is attached to the intake.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
the reason i called it a heavy pig was becasue my 68 with a 390 really seems mor eheavy in front than i thought it shoul dfeel when driving it. maybe it has to do withthe rearend gearign or the auto trans. becuase the heavy feeling could also be described as a held back type of feel when you let off a little. itfeel liek thereshould be a more open glide or roll to the truck when moving down the highway.
