Getting bushings inserted tips?
- Great90wt
I'm replacing the front axle pivot bushings and the rear spring bushings. I've quickly found out what a bear that is. Any tips on getting them in? I don't have a shop press right now. I've tried putting a bolt through and torqueing it down. I snapped the bolt I was using on the axle bushing. I'm using grade 8 bolts on the spring bushings and they will only go in about 3/4 of the way. Any suggestions?
1967 F100 4x2 slowly coming together from pieces
re: Getting bushings inserted tips?
Take them to a shop and have them pressed in.
I agree, take them in. There is not enough cuss words out there to make it any easier.
- ivansgreat
I suppose taking it to a shop would be the easiest thing to do. My dad and I used a bolt like you did and we got it done. It was pretty hard though.
Ivan
1968 F100 2wd
302
1968 F100 2wd
302
Either that or go buy yourself a hydraulic press for your shop...then charge your buddies to change theirs!
