want to convert 4X4 Dana 44 from drum to disc
I've got a '69 4x4 with a Dana 44. What do I have to do to make this a DISC brake set-up. Slightly modify...or swap with new truck front-end??
Swap the whole frontend to an open knuckle disk brake D44 or D60.
As far as I know there is no kit offered to do this conversion on a closed knuckle D44.
- Wes
re: want to convert 4X4 Dana 44 from drum to disc
I did this swap to my son's 67, I used a 77 F250 d44. bolted right in. only change needed was the steering link. I believe that up to 1975 the d44 on Fords were all closed knuckle, very hard to find parts for. The 76 -77 1/2 model years used open knuckle.
Some pictures here http://www.ford-trucks.com/user_gallery ... bumid=6096
Did you got to an adjustable link?
By the way,
to the site. Hit the welcome mat. We like pics
By the way,
- Wes
Yes I havn't finished it yet we're going w/ P/S as well but I have an adjustale link from a mid 70's 3/4 ton 4x4 suburban that looks like it will adjust to the right size. Adjustable make more sence you can center the steering wheel w/o moving your alignment.
Wes
Wes
what PS set up are going with?
Thanks for the info guy's. Right now I'm just going to replace the hub. But eventually I will be converting. You guy's gave me the goods to keep an eye out for.
thanks
thanks
- broke_okie
I swapped in a high pinion disc brake dana 44 out of a 76' F100 4x4. I picked one up at a local yard for 100 bucks but then I put about 350 bucks into it but it was worth it.
J.P.-"Happiness is... not being smart enough to know what to worry about."
** 1971 F100 SWB 4X4 SPORT CUSTOM**
