fuel tank selector switch
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
I could use a little info. Is there a trick to taking this switch off?
I want to clean and lube it. Harness doesn't want to pull off back. I certainly don't want to damage it. Thanks for any help. Guess I could take the bracket nuts off and lower the whole thing down, and go from there.
May your sails stay full, and your knots not slip. Unless a slip knot.
Once I thought I was wrong, but I was wrong.
Life is a banquet, and every days a feast.
68 F-250 CS 390 C-6 P/S A/C front disc. 2nd owner.
2016 GMC Terrain Denali 301 HP V-6 AWD.
2009 Silverado Crew Cab, V-8, 4X4.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- fordamericana
Re: fuel tank selector switch
There is a tool for that, same as the one for the headlight switch. If you don't want to damage it, I'd get the tool. Other wise, once you remove the knob, you can technically remove the retainer with a pair of needle nose pliers, some cussing, and scratch the heck out of all sorts of stuff on your dash.Mancar1 wrote:I could use a little info. Is there a trick to taking this switch off?I want to clean and lube it. Harness doesn't want to pull off back. I certainly don't want to damage it. Thanks for any help. Guess I could take the bracket nuts off and lower the whole thing down, and go from there.
Not that I know from experience...
I likes My FE I does...
- fordamericana
The proper tool for the job...
http://compare.ebay.com/like/2003776678 ... 602_304662
Took me a bit to find it, but if you don't want to damage anything, you will need this. I have been told you can also make one with a piece of pipe, a hacksaw and file...
or if you want to remove the whole bracket you can remove the instrument cluster to get to the bolts.
- Mancar1
Thanks for the info. I will get the proper tool.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- Mancar1
Thanks I am ordering the tool. No one has it local. Hope cleaning up that switch helps my gage readings.fordamericana wrote:The proper tool for the job...
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
- fordamericana
Yeah, they are kinda hard to find pre-made, but worth it, or at least I think so... Glad to help.Mancar1 wrote:Thanks I am ordering the tool. No one has it local. Hope cleaning up that switch helps my gage readings.fordamericana wrote:The proper tool for the job...
