Why's a ford take so long to heat up?
- rjewkes
seriously i need more than 5 miles even at 55mph to get the truck hot and the same goed for the '89 Cougar. I'm This close (inches and long) to getting a heating blanket or block heaters or dipsticktube oil heaters to keep them warm or even one of thos ceramic power port(cig lighter hole) Hang from window heaters to atleast get the cabin warm.
- Ranchero50
Re: Why's a ford take so long to heat up?
Very simple fix is remove the heater core hose that comes from the intake and put a restrictor in the hose with a 5/16" drilled hole. This will slow the flow of coolant through the engine while the thermostat is closed causing the coolant and thus the engine to warm up faster. Think about it, the heater hose is 5/8" so that's still a lot of cold radiator coolant thats cycling through the engine even with the thermostat closed. If you restrict it hose to 5/16 there is a lot more time for the coolant to warm up and it won't overheat because the main thermostat will open.
Ford did this in the mid '80's for emissions and most end up in the trash at heater core replacement time because they restrict the flow (thus keep the heater from putting out full heat in theory). Your Cougar should have one side of the heater core with a larger tube. That's where the restrcitor goes.
Jamie
Jamie
all i can say is there is no reason for it to be this cold all of the sudden. shouldnt the weather gradually get colder so we can get used to it easier. it done the same thing to us last year. it was mild and then it dumped all that snow on us without warming back up for over a month or two. just to slightly melt the snow off.
Move out here to the desert, it's going to be 80 today.fordman wrote:all i can say is there is no reason for it to be this cold all of the sudden. shouldnt the weather gradually get colder so we can get used to it easier. it done the same thing to us last year. it was mild and then it dumped all that snow on us without warming back up for over a month or two. just to slightly melt the snow off.
But seriously, try the restrictor method.
i just start my bump about 10 minutes before i leave the house.i is nice and cozy by then and up here in south dakota it gets down right nasty cold i also put a piece of cardboard with a few holes cut out for just a little bit of air to come in works great .just my
- GSequoia
Yup. I went on a ride down to Orange County on the motorcycle and had to remove my jacket liner! Hello Christmas, time to go to the beach.Racer Z wrote:Move out here to the desert, it's going to be 80 today.fordman wrote:all i can say is there is no reason for it to be this cold all of the sudden. shouldnt the weather gradually get colder so we can get used to it easier. it done the same thing to us last year. it was mild and then it dumped all that snow on us without warming back up for over a month or two. just to slightly melt the snow off.
www.advlifestyle.com
1971 Camper Special (390 / C6 / D60)
1970 F250 High Boy (NP435 / Dana 24 / No engine, rusted to hell and back body, project to combine with above.)
1966 Rustang (289 / C4 Project stalled for ages)
1989 Jeep Cherokee (4.0 / Auto / D30 / D44 / 35's)
1996 Jeep Cherokee (4.0 / Auto / D30 / D35)
- ccryder2011
let it warm for a 10 mins at idle before you leave... at higher speeds it actually cools the engine better especially when its cold outside...it gets subzero here in ct and as long as i can get it to start ,im warm when i leave the house...!
remember the key is to start what you finish....
....happy cruising...
1967 f-100 sb,mine
2007 subararu wrx,son#1
2003 mitsubishi eclipse,son#2
2007 mercedes E 350,wifes
1967 f-100 sb,mine
- SteveC
My 67 took for ever to heat up. I replaced the radiator and walla it warms up reallly quickly now.
Course the heater core is fairly new as is most of the cooling system
I don't really care about brands Chevy Ford Dodge ...as long as it doesn't sound like two old dudes farting in a coffee can.
http://s169.photobucket.com/albums/u223/imabaka70/ Projects listed on the left side
WOOOT!! i passed my mechanics classes. Now working as a mechanic and waiting to go for my ASE certifications.
1967 f-100 4x4
1969/72 f100 351w EFI m5r2 5 speed
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- 1969FordMan
I had a problem with my bump warming up last saturday. it usually gets warm withing 5 minutes, but after 10 miles it was still blowing ice cold. a couple minutes later I realized I had left my vents open (boy did I feel stupid)
Growing up my dad had a 1990 crown Vic, took that car FOREVER to warm up (like 15min) We never knew why. But it took 10 miles at least for it to warm up. That thing would freeze you to death!
1969 F100. All factory 360, 4-speed, candy apple red one owner. Incredible truck!
- 1971ford
Since I just got the electric choke hooked up on the highboy DD, I can hop in on a very cold california morning (it hits 30 degrees sometimes, and that's COLD ) turn the key and it fires instantly then I'm on my way in 5 seconds... heater gets the cab toasty with in a couple minutes.
-Ryan
The electric choke has no bearing on the water temperature.1971ford wrote:Since I just got the electric choke hooked up on the highboy DD, I can hop in on a very cold california morning (it hits 30 degrees sometimes, and that's COLD ) turn the key and it fires instantly then I'm on my way in 5 seconds... heater gets the cab toasty with in a couple minutes.
So far I don't think anybody mentioned the thermostat yet. And, there is, at least when it was new, a water flow control valve to the heater. This valve could be shut or clogged. There is suppose to be a bypass for the heater so water can flow when the valve is closed.
Over time, engine blocks and head passages will build up rust and scales. This causes heating / cooling problems.
The passages in the heater and radiator cores tend to clog up over time as well.
When was the last time you changed your water/antifreeze and flushed the cooling system?
Let's not ignore the water temperature sending unit and the gauge. Have you actually tested the water temp with a second gauge, such as a meat thermometer?
When the engine is cold, remove the cap and stick a meat thermometer in the water. Start the engine and wait. You can grab (I got an electric fan so this is easy) the heater hoses and feel the warmth starting. When the thermostat opens, you will know it cause you will see the water flowing. If you have a 180 thermostat, the meat thermometer should now read 180. Go look in the cab at the water gauge.
How long did it take for the thermostat to open?
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
I'm surprised that no one else beat me to this technical answer. It takes em so long to heat up cause they are so
May your sails stay full, and your knots not slip. Unless a slip knot.
Once I thought I was wrong, but I was wrong.
Life is a banquet, and every days a feast.
68 F-250 CS 390 C-6 P/S A/C front disc. 2nd owner.
2016 GMC Terrain Denali 301 HP V-6 AWD.
2009 Silverado Crew Cab, V-8, 4X4.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
My 390 takes about 10 minutes to really warm up. I can watch the temp guage slowly rise up to 190ish, then fall back to 160ish when the thermostat opens, then creep back up to about 185. It's at that point I know it's ready to go. Sometimes I'll take off before but, I try not to. just cuz an engine will run when cold doesn't mean it's good for it. The temp here this morning was about 17 degrees. That means the engine will start at 17 degrees and run up to 190. You'd be surprised at how much the iron, steel and brass expands and contracts within that range. Throw too much power on it when it's cold and loose and you might end up with oil, coolant and vaccum leaks. I'm famous for leaving the oxygen valve open on my torch for days at a time. In the summer it's not a problem but, in the winter, if it gets cold enough, the brass in the regulator will shrink enough and all 2000lbs will be gone in the morning.
It was so cold here last nite I had to put thermal underwear shirts over my chickens like a blanket!
When I lived in Missouri, I would start my old Chevy, set the defroster on and go back inside for ten minutes.
But here in So Cal, it never gets truly cold. I let my Ford idle for a few to get the oil flowing properly and go.
The Ford was taking forever to warm, and then refused to cool. Changed a few minor things that didn't seem to help. A few months later water started mixing with the oil.... Put in a new motor, new thermostat, new temp sending unit and now it seems to be fine. And yes, I got a bit anal about making sure all of the cooling system was working correctly. Didn't want my new motor to, well, you know, have problems cooling.
