Leaf Springs
- wcm473ciford
Leaf Springs
Hi again , I made the mistake for the 3rd time of letting my son drive my
truck , I wont go into the other two but this time he busted the housing
and ripped out the pinion gear . I have replaced all of that but when he
did it he twisted the leaf springs and now they're bent in the wrong direction . Does anyone know which years are interchangeable for
the springs and I guess I need heavier duty ones so if you know if
any 3/4 ton or whatever is thicker than what was on it will fit I'd
appreciate it .
Thanks ,
Bill
appreciate it .
Thanks ,
Bill
Bill
re: Leaf Springs
A 5 lug D60 might be an idea for the forth time.
- boots
re: Leaf Springs
how did he do that??
Ethan
67 f100 - 4"lift - cut fenders - 36 TSL's
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
http://www.fordification.com/forum/view ... 835#136835
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- wcm473ciford
re: Leaf Springs
I wish I had a clutch with a 4 speed but its a C6 , he was backing up which makes both wheels spin and must have been on some asphalt that gave it very good traction . It torqued the rear end upward and bent the springs along with the other damage .
Bill
Get an axle wrap bar (traction bar). That will save the springs anyway.
http://fordification.com/forum/viewtopic.php?t=6772
- wcm473ciford
re: Leaf Springs
Thanks for that idea , I should have thought about traction
bars before but I still have to replace the springs , I'm just
trying to find out what year range I have to find some .
Bill
Bill
Bill
- bluef250
re: Leaf Springs
Just a suggestion, take truck to good spring shop and let them install new springs. They might have some suggestions about stabilizing the rear.
the kit says for 66-79, would it work for a 65?heep70 wrote:Get an axle wrap bar (traction bar). That will save the springs anyway.
I don't know if the one from Bronco Grave yard will fit a 65. The one from Sam's will fit anything. You weld it to the axle housing and will more then likely have to fab a crossmember bar for it to bolt to.
- wcm473ciford
