I don't have any shift linkage on the transfer case right now because i haven't adapted it to fit the dodge transmission yet so i juts crawl under the truck for now.
I forgot the shift pattern so just moved the t-case bar in and out until it was not in low range and the driveshaft didn't spin. This is when the bar is pulled all the way out.
But now that I look at the shift pattern, all the way out would be 4HI, so why could I spin the driveshaft
Now when I drive the truck, occasionally I'll be cruising and all of a sudden it starts revving up. Crawl under it, and the linkage has pushed into the t-case. Yank on it to pull it back out all the way and away I go.
Seems I have shenanigans going on here
Np205 swap in the future but for right now...
