Steering question
Steering question
Hey guys. I need help with the steering setup on my 4x4. The truck is a 68 F250 frame with a 70 F100 body on it. I'm wondering if the steering setup is correct or not. Could somebody post a picture of a stock gearbox mounted to the frame? Thanks
Troy
Why is it that the trucks are always the best running vehicles in the family?
Ford means "found on road daily"
70 F100 Custom-352 w/68 Highboy 4x4 frame. My play/project truck
70 F250 Explorer-390/C6 auto. My work truck
04 Mitsubishi montero-family car
- 71PA_Highboy
Re: Steering question
If the sector shaft is horizontal and coming out of the side thru a hole in the frame it is an F250 4x4 box.
If the sector shaft is vertical, it is not an F250 4x4 box.
If you still need a pic tomorrow, let me know.
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Troy,towtruckerfour on Sat Mar 10, 2012 12:01 am
Here's the schematic for the highboy with manual steering.
I can't seem to be able to find one for a highboy with PS.
http://www.fordification.com/tech/image ... column.jpg
Hey guys. I found this picture I took when the body was off. This kinda shows what I have. Looking on the Oreilly website, it looks like a 2wd gearbox. There is a notch cut out of the frame on the inside where it mounts and a plate welded on the outside for strength I guess. That is why I'm thinking this is not original.
Troy
- averagef250
if it has 3 bolts it's a 68-79 2wd box, 4 bolts it's a 78-79 F-250 4x4 box. Judging off only what's in your picture I say 78-79 F-250 4x4 box since it appears to be the same height as the frame rail and the pitman arm is from a 78-79 F-250 4x4 box, not a 2wd app.
It has three mounting bolts so I'm guessing its the 2wd. It works but is leaking fluid all over the frame. Is this a common upgrade? I was considering rebuilding it but have never done one. Oreilly has a new one for around $160.00.
Troy
- averagef250
The seal kit's like $15. Any old ford shop manual explains in detail how to take it apart, re-assemble and adjust it.
DO NOT DISASSEMBLE THE BALLNUT! No reason to do so and if you do you will make tenfold more work for yourself.
Re: Steering question-update
Ok. I pulled the gearbox out and now I can't really tell where the leak is from. The gearbox has 4 mounting holes so I'm thinking you were right Dustin. Here is a better picture of the box and pitman arm. You can see in the first picture how they modified it to fit.
They both have D7 numbers on them so it is definitely not original. I might try rebuilding it so I know it has no leaks.
Troy
- mybros71
Here's what my bro's 71 F250 looked like pre-power.
Tony
2006 Mustang GT (Wife's)
1962 Comet Custom (Wife's)
1971 F100 2wd Prerunner Project (Daughter's)
1971 F250 4wd "The Beast" (Son's)
2007 Toyota Tundra 4wd. (Credit Union's)
Seriously, the best truck I've ever owned, without exception.
Thanks for the picture Tony. I bought a kit and swapped out the main seals that I could get to. It was not as bad as I expected. It is back in the truck and works good so far. I bought a new pressure line also since it was all apart anyways. Thanks for the help guys. By going off the casting numbers, this steering box was out of a 77.
Troy
