major toe-in problem...maybe...?
- Billybobjunky
Put a '77 front end on the ole '67 including the '77 coil springs, i believe the 77 springs were for the V8 application or something because they are taller then the original ones I took off. I figured this would work bc the original springs were matched to the trucks inline 240. Well it now has a 351m, so should these newer springs be ok, bc right now, truck empty of an engine, I get major curve-under. Think this will level out with the additional weight of the motor? See for yourself...Right SideLeft Side
1967 SWB 2wd F100
-'77 V8 [[[410]]]
-'74 C6
-Re-wired main harness
-Disc Brakes/Power Steering
-'77 V8 [[[410]]]
-'74 C6
- Heavenlyfire
re: major toe-in problem...maybe...?
I agree, Its fine
Mine's the same way. By the time you get the engine, tranmission, and all the bodywork back on it, it'll settle down. Don't worry.
- rjewkes
Mine did half that with the front sheet metal and radiator & support out of it.
