Place for factory wiring
- spartman
I found this place and you can buy wire by the foot.
If you look down the list it has ford factory correct wiring to replace wiring on our trucks.
That way it would look stock instead of just adding another red,blue,green,or yellow wire under the hood.
http://www.riwire.com/Catalogs/sup/pages/wire.htm
- 1968flareside
Great link for that spot repair in the harness!
1968 F-100 Flareside
1999 F-150 XLT 4X4
http://www.fordification.com/galleries/ ... ?cat=10023
and
DON'T FORGET!!
1999 F-150 XLT 4X4
- 1968flareside
re: Place for factory wiring
Well, that's one hurdle I've already defeated. I used a universal Painless harness. Everything is all wired up! Here's a really bad picture of when I was still wiring it up...
Do you notice the updated style fuse block? It puts my mind at ease to see more than a handful of fuses on the system. Plus, I can add power windows, locks, a/c, power antenna, 3rd brake light, cargo light, and elect. fuel pump.
1999 F-150 XLT 4X4
and
DON'T FORGET!!
1999 F-150 XLT 4X4
- Heavenlyfire
Re: re: Place for factory wiring
Was it painless to install?1968flareside wrote:Well, that's one hurdle I've already defeated. I used a universal Painless harness. Everything is all wired up! Here's a really bad picture of when I was still wiring it up...
- trukcrazy
Did you take plenty of pictures so we can all see how easy it was? A rewiring writeup would be helpful here.
John, #424
1967 F250 crewcab x 2.
2010 Dodge Ram 1500 Sport Quadcab
2008 Challenger SRT8
- 1968flareside
I did take several pictures, but the only camera I had was a camera-phone. The quality is not that great and it doesn't show too much that would help, just big nests of wires everywhere. I can take a few better quality pics of exposed parts now to include.
It was fairly painless, but very, very time consuming. I can do a write up on it along with the Mustang tank install write up.
One quick tip, you need to retain all of your Factory Ford pigtails. The only new, replacement pigtail I could find was for the ignition switch. That was from a company based in Canada. You will still need a wiring diagram for your specific model year also. They don't make a Ford specific application, so a universal harness is required.
1999 F-150 XLT 4X4
and
DON'T FORGET!!
1999 F-150 XLT 4X4
- 1968flareside
Ok, I'm a little p.o.'ed, but happy for you guys. I just found a specific harness for our trucks http://www.painlesswiring.com/webcatalog.asp
Here's a price quote from Jegs...
http://www.jegs.com/webapp/wcs/stores/s ... ryId=20003
This one from Summit lists the same part # but says it's universal...
http://store.summitracing.com/default.a ... &x=25&y=13
This is the one I have for almost $300 less.....
http://store.summitracing.com/default.a ... search.asp
I know that Autozone is an authorized dealer as well. Just do some shopping around.
www.blueovaltruckparts.com has this one too...
http://blueovaltruckparts.com/catalog/p ... s_id=12381
That one is around $500 as well. I guess it just depends on what you want. Anyway, there's some ideas for everyone.
1999 F-150 XLT 4X4
and
DON'T FORGET!!
1999 F-150 XLT 4X4
I just got a 12circuit painless fuse block that I will be adding to my truck. My harness is good, I just plan on adding air, electric fan, power windows, shaved door handles, xm radio, cd changer, so I don't wanna overload the poor little fuseblock or have all kinds of taps going to existing fuses.
I will take pictures once I start. You can find very good deals on ebay for new painless fuseblocks. I got mine for 65 bucks.. sells for 90 on summint or jegs forget which I checked.
As always, just my
Patrick
As always, just my
Patrick
Chevrolet
Can Hear Every Valve Rattle on Long Extended Trips
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
http://www.fordification.com/galleries/ ... ?cat=10336
HELLO To all, i found a co. in pa. called ron francis with complete wireing kits, also send for a catalog or call and talk to the oner about your needs. I have seen alot of kit's installed at shows and i see this co. more then pain less. ron fraincis .com We are almost ready to do this so any input would be helpfull .Any surprise other than plugs from old harness?
- binder56jd
i have read some good reports on the ron francis wiring-jd
http://www.ronfrancis.com/showpage.php?page=main.htm
now serving #235
now serving #235
