Dana 24 Speedo gear???
I was wanting to know the best way to go about getting a gear that would correct the speedometer on my 67 4x4 with a type24 Dana. The Type 24 has a cast gear inside the case that the speedo cable attaches too. My truck originally came with 4.56 gears and I switched to 3.73 and my speedo reads really slow. Didn't know if there was a source for these gears.
Re: Dana 24 Speedo gear???
I would try to figure out which one you need. Then find the part number. Then try one of the NOS dealers such as Green sales or any of the others. Kind of alot of steps but it'll be worth it. I believe most of the info you need will be available form this site.
Doug
Doug
1967 f100 4x4
1970 f250 4x4
1970 f250 4x4
- averagef250
Use an inline speedometer ratio adapter. Do some basic math to determine how far off the speedo is then buy the exact ratio adapter to correct it. Installs in 5 minutes.
- Tpdaniels
http://www.transmissioncenter.net/speed ... 7QodbBMelQ
About 1/3 of the way down on the page, it's listed under "GM / Dodge / Ford Ratio Adapter" Cost $62.00, This is about the only way to fix them. You can get most any Ratio change needed to speed it up or slow it down.
I am of an age now that most of life's lessons were learned the hard way;
Life is hard, but it’s harder when you’re stupid.
Never approach a bull from the front, a horse from the rear or a fool from any direction.
Never ask how stupid someone is 'cause they'll turn around and show you.
Light travels faster than sound. This is why some people appear bright until you hear them speak.
If you had the choice “Looks or Brains” take the Brains, Looks will get you thru the first half, but Brains will last a lifetime.
I was always under the impression you could just change the plastic driven gear on the end of the cable to correct?
DC and NPD sell the different colored plastic ones for around $12 I believe.
- averagef250
There is no gear on the end of the D24 cable. Regardless, in any speedo drive setup if you change one gear you have to change the pitch center or both the driving and driven gears need changed at the same time. Fords don't use any kind of pitch center adjustment that I'm aware of so your stuck with changing both gears.basketcase0302 wrote:I was always under the impression you could just change the plastic driven gear on the end of the cable to correct?
Chrysler and GM products really loved the ratio adapters for decades. A stroll through U-pull-it could get you a bucket of them for a few bucks.
- Tpdaniels
I was waiting for someone else to answer before I replied, I knew you couldn't just change the plastic gear, I looked for months during the rebuild of my highboy and the only way without taking the transfer case apart, (not to mention you can't buy the replacement speedo gears) is to use the gear adapter, it just screws onto the transfer case and the speedo cable screws onto it, it's simple and only takes a few minutes to do.averagef250 wrote:There is no gear on the end of the D24 cable. Regardless, in any speedo drive setup if you change one gear you have to change the pitch center or both the driving and driven gears need changed at the same time. Fords don't use any kind of pitch center adjustment that I'm aware of so your stuck with changing both gears.basketcase0302 wrote:I was always under the impression you could just change the plastic driven gear on the end of the cable to correct?
The only problem with a used one is they come in any ratio correction from -50% to +100% and anywhere in between, good luck finding the right one
Here's a picture of one
Thanks TpDaniles! I never saw one before. How do you figure out which one you need? I need to speed mine up about 12mph.
- averagef250
Does it read 12 MPH when you're stopped?Ks Highboy wrote:Thanks TpDaniles! I never saw one before. How do you figure out which one you need? I need to speed mine up about 12mph.
- Tpdaniels
To start with what you have to figure out is the percentage of increase you need. I'm assuming your saying that at 55 mph your speedometer say's 43, to find the percentage, divide the correct speed (55) by the incorrect speed (43) and the answer is 1.279 if that's the case you need an increase of 27.9 percent to correct the reading. If you look at the the site I referenced,averagef250 wrote:Does it read 12 MPH when you're stopped?Ks Highboy wrote:Thanks TpDaniles! I never saw one before. How do you figure out which one you need? I need to speed mine up about 12mph.
(http://www.transmissioncenter.net/speed ... 7QodbBMelQ)
you will see one of the adapters they stock is a 28 percent increase, that is as close as you can get, so that's the one you need.
And the answer to your question is NO, it reads zero when stopped. By correcting the percentage it will be correct at any speed your driving
Hope this helps.
