Frame flex
Frame flex
Hello! I'm new here. My '69 F100 2wd's steering felt a little loose so while I had an assistant turn the wheel back and forth I noticed the steering gearbox moving. I found the three bolts less than super tight so I retourqed them. This helped alot but I still see the box moving a little. I think it's frame flex and am thinking about welding up a plate to reinforce it. I've never heard of this on a 67-72 Ford truck before, (unlike chevy's that always crack the frames or pull out the bolts.) Anyway, if someone can check theirs for me and let me know if this is normal, (mine has power steering). Thanks!
HHHmmmm, never heard of this on a Ford. Sorry, I can't help ya on this one. I do have PS but it is on my "Highboy". Hang on and someone here will help ya out.
By the way, stop by the "Welcome Mat" and intro yourself and the your Ford.
re: Frame flex
I really doubt that you're seeing frame flex in that area. I've never heard of a frame cracking there on a 2WD...the frame is boxed in that location, so it's darn strong. If it was flexing there because of broken welds, it should be obvious. I'd guess that while the box was loose you got some grit/gravel down between the mounting pad and the box. I'd suggest just removing those bolts and pulling the box away from the frame enough to really clean it up, the box and it's mounting pad.
- marz68
- 390Nut
re: Frame flex
I've seen signs of it once before as well, on a `68 F100 parts truck. Steering gear was a bit loose, and looking at the bolts, the metal on the frame where they went through was stretched a bit, and you could see what looked like little dents, almost like they were countersunk. It was the only one I've ever seen like that, so I chalked it up to a bad bit of steel on that particular frame, that was a little softer than normal.
`69 F100 390 4spd driver
http://www.fordification.com/galleries/ ... ?cat=10251
Dura-Spark II Conversion info at:
http://home.comcast.net/~390nut/Dura-SparkII.htm
Pipes71 did once say, "bumps and bikes.. what a great combo!"
- bluef250
- mrung0wa
re: Frame flex
You also should consider replacing those 3 bolts w/new grade 8 one's. It's possible that they have lost their tensile strength through age and or over torque/tightening. This occurence in not common under normal situations.
Make sure that the mating surfaces are clean, dry and free of debris.
Lawrence
Lawrence
http://www.fordification.com/galleries/ ... ?pos=-2746
FOR SALE: 64 Galaxie 390HiPo C6 (Project Car)
SOLD! 69 F100 Contractor SPECIAL 300 I6 "Jethro"
01 BMW 325i 4DR E46(Wife's car)
03 EXPEDITION XLT FX4(2WD/AWD/4WD) 5.4L K&N FipK
"I beat my head against the wall, Because it feels good when I stop."
- 72hiboy4x4
A company I worked for years ago had a mid-80's
F-250 that they loaded with 55 gallon drums of diesel (for the loader on the jobsite).
Got about 1/2 up the logging road, and broke the frame clean in 1/2 right behind the cab.
I have heard those years are not very strong frames.
And to get back on topic, I personally have never seen a frame problem at the steering box on our year truck. but, thats not to say it can't happen!
In life many men take the path of righteousness, some take the path many others follow (G.M. owners, for example), some take a more arduous path, some a simpler path. I, sir, took the PSYCO-PATH!!
re: Frame flex
Your pretty observant. Yep, it moves there. The long pitman shaft is
what does it. Solution? Make a cross brace that clamps onto the steering
box at the bottom where the pitman arm comes out and run it accross to
the other framerail.
- mrung0wa
re: Frame flex
Lawrence
- marz68
re: Frame flex
- mrung0wa
Yeah, but it has that pungent odor about it!Jake11 wrote:Eucalyptus is purty strong
Hey Keith P. did you get my PM?
Lawrence
