What did you do to YOUR bump today?
Re: What did you do to YOUR bump today?
Painted engine bay, rad support, engine supports and gear box. Took I beam axle bushings out to replace them.
Thanks JP! Ms. Cordova is a factory 1969 Ford F100 Ranger with a 390, Front disc brakes, Cordova copper orange, behind the seat box
- Salty Dog
Bought a clutch and brake pedal pad. Oh and I picked up some reverse light bulbs
72 f100
360
360
- abe
Within the last 2 weeks I made a new backboard for my 70 F350. For you scavengers, like me, you will be pleased to know that the 2x8 I used I dug out of a dumpster at a houise that was being renovated. It fit almost perfect, being about 1 inch too short!
Here is a pic with the old board I used the last year, which I made quickly and cheaply.
p
Here is the new board I made from the scrap (reclaimed) 2x8.
Here is a pic after I took it down into my basement shop and painted it during these cold PA days.
I even drilled a hole into the center post so I could use the lever to hold the post in the pocket as Ford had designed it!
1970 F-350 flatbed dump, purchased 9/20/12
1954 F-100 bought from Grandpa in 1977 for $200
Painted the frame gloss black (second round) and prepping for frame re-assembly. I do more, but awaiting paint to dry!
""Never shoot a large caliber man with a small caliber bullet."
2017 Ford Raptor
1948 Willys CJ2A w/ Ford Flathead V-8
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
- SevNT2Bump
Replaced the plastic thing holding my rear license plate on with a metal bracket. The plastic piece found it's destiny in the trash can.
Ken
72' F250 Custom 2wd 360 C6 auto
99' GMC 1 ton dually flatbed 454
07' Ford Ranger 2wd 4.0 Sport
- KRob
Busted some snow drifts and worked on the new gauge cluster.
71 F250 4x4, 4BT Cummins Mostly Done...Project Thread http://www.fordification.com/forum/view ... 22&t=65450
(4BT, big block ZF5, 78 NP205, 78 Dana 44 Front axle, 4.10, 265/75/16, power steering, power brakes)
01 Dodge 2500 4x4 Cummins...turned up a little.
- WarEagle
Now that the motor is running/ idling good, need to hook up a muffler and exhaust. Looking at the Dynomax ultra flo X. it has an x pipe in the muffler itself so I don't need to make one. Its kind of new so I don't see too many reviews.
1972 F100 300 cid straight 6
2009 F150 4.6L Super Crew
- Mancar1
- Location: USS Gramps Garage (DD-727) Tehama County, Northern Ca.
Put a new ign switch in.
May your sails stay full, and your knots not slip. Unless a slip knot.
Once I thought I was wrong, but I was wrong.
Life is a banquet, and every days a feast.
68 F-250 CS 390 C-6 P/S A/C front disc. 2nd owner.
2016 GMC Terrain Denali 301 HP V-6 AWD.
2009 Silverado Crew Cab, V-8, 4X4.
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
DD-727
DD-806
AE-35
LSD-39
AS-41
AR-8
Moved it so I can get the wife's van onto the concrete. Need to replace the water pump and lower hose on the van. It's supposed to be in the upper 60's today, so it should be a nice day to work on it.
- SevNT2Bump
Just got back driving my truck from San Diego to Borrego Springs, over to Yuma, AZ and up to Ferguson Lake on the Colorado River. Then returned the same way. Needed to get some catfishing done with my Dad for a few days
It was 480 miles round trip, with 20 of that being a dirt road. My truck was full of camping/fishing gear and was pulling my boat. It's done it twice with no problems. This is what I got this truck for.
I'm liking those plaques!
Ken
Yup! That's what these trucks are for!
Pulled the 460 out and put new freeze plugs in it. New battery, new starter and new cables while I was at it. Replaced the exhaust manifold gaskets and put in new donuts. Put it all back in, good days work. Wish I had enough money for a new converter while I had it out, stock one sucks.
Ready for spring if it ever gets here......
Larry
Larry
67 Camper Special Ranger
460/C6, PS, PB
Too Old Building Contractor
460/C6, PS, PB
Stripped the Dana 60, removed all the bearings and races, and cleaned the housing in prep of an overhaul. All I have to remove is the ring gear bolts as I am going to upgrade from a Factory locker to a Detroit Locker. I just have to get a helper or figure out how to hold the differential in order to break the bolts free!
2017 Ford Raptor
1975 Ford Bronco
2017 Ford Raptor
1975 Ford Bronco
Finally ordered all the parts for my cooling system overhaul from summit racing. Need to pick up upper an lower hoses at the local parts store with fluid an new belts an i should have the Highboy running by sunday if all goes well
-Mike-
ECV 1849
Build>http://fordification.com/forum/viewtopi ... 22&t=68225
69' F250 Highboy 390ci.,NP435,Dana 24,HPD44,D60
67' Dodge Coronet R/T 440ci.4speed,D60, all numbers correct
72' Dodge Dart 440ci.727,D60,10ptcage street strip on meth 10.40s
05' Chevy Tahoe LT loaded for the wife an the baby duty
12' Ford Focus Titanium Hatch Back, Gas saver for the work week
ECV 1849
- 1970Custom
I think I should join in on this thread.
Working on the exhaust for my F-600.
Also pulled the side rails and cut the liftgate loose, getting one step closer to my work truck....
Hi, I'm Eric and I have a bumpside addiction.
