heat gauge not working
- Junior Knight
the gauge was working till the wire got on the intake..so i put the wires back together, installed a new heat sender in the intake, it still wont work...what am i missing?
1967 Ford F-100...goin back *STOCK*..just sayin
Re: heat gauge not working
Is the oil pressure gauge working? They have the same power source. If it is then you have eliminated that as a possible source of trouble. Need to ground the temp sender wire and see if the gauge responds. If nothing then I'd pull the cluster out for inspection.
1967 F-100 4x4 custom cab.
Another 67 F-100 4x4 custom cab.
2016 F-150 Eco-Boost 2.7 liter. (It will smoke the tires!)
1972 F-350 Sport Custom cab & chassis.
1972 F-250 Explorer Special, Camper Special.
1971 F-100 custom. 302, C-4, p.s. p.b. factory 65 amp alternator with transistorized voltage regulator.
- Junior Knight
have done all of that...nothing..
So does your oil pressure gauge work?
Sorry for jumping in here. I have the same problem and both heat and oil gauges not working. Where is the power source for both these gauges?
I didn't know they had common power source.
http://fordification.com/tech/wiring/wi ... gauges.jpg
The power for both gauges comes from the instrument cluster voltage regulator. There should be a pulsing voltage coming out of it and averaging around 5 volts I think. You should have this voltage at 30 A and 30 B with the key on.
- Junior Knight
just checked the oil gauge..its not working either..ordering a new ivr...thanks for the help
