maybe i am wrong but 67 is different size then 68-72Bill Ramsey wrote:are you sure?67 short box wrote:I have a 67 and a 72, even changed the 67 for the 72. identical except for the button
1967 glove box door
Re: 1967 glove box door
i took the 72 out and bolted it to the 67. fit good,
what am I missing? I was playing around with different colors.
a 72 cant fit in a 67,there different sizes67 short box wrote:i took the 72 out and bolted it to the 67. fit good,
post your vin#,someone will tell you what year,what is the year on the title,
well the 72 has a build date of 5-72
has the 72 grill it has a tag on the inside of the glove box about the jacking instructions that the 67 does not.
it fits perfectly
it fits perfectly
they are all the same. I was being sarcastic earlier. you can take a glove box door from a 1972 F600 and install it on a 1967 F100 if you wanted to.
or a 1978 F600 for that matter. all same.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
1976 Highboy
VW Sandrails
Honda ATC's
got me all worked up! I don't get to be right very often!!
