Front parking brake cable
Hello all, I am in need of a front parking brake cable for a 72 f250 4x4. Can't seem to find one anywhere.
If someone happens to have one or even a part number I'd be happy. Let me know what you may have and a price. Thanks
- idaho_cowboy
Re: Front parking brake cable
(ignoring reply above)
Inline tube, can make one if you send them one to duplicate.
https://docs.wixstatic.com/ugd/4d7af2_9 ... 27156f.pdf
Chris
1948 F47
1970 Boss 302
1970 Ranger XLT
1978 Monarch
1987 Monte Carlo SS
2015 F150
Chris
1948 F47
1970 Boss 302
1970 Ranger XLT
1978 Monarch
1987 Monte Carlo SS
2015 F150
I need the whole thing. Cable was cut due to fire so I'm trying to get a part number so I can get one or I'd take a good used one. I had the number for it at one point but can't seem to find it now. Thanks for the info though
any luck finding this part? i need one too.
1968 Highboy
1976 Highboy
1969 F250 Camper Special
1941 Dodge Power Wagon
1930 Model A Coupe (Hotrod)
1962 Fairlane 500 Sports Coupe
VW Sandrails
Honda ATC's
36' Diesel Pusher for roughing it.
1976 Highboy
VW Sandrails
Honda ATC's
I found local wrecking yard. This is the difference 2wd vs. 4wd.[image][/image]
1968 Highboy
1976 Highboy
VW Sandrails
Honda ATC's
1976 Highboy
VW Sandrails
Honda ATC's
That looks adaptable.
I got my FRONT PARKING BRAKE CABLE made for my 67 f-100 4x4 made by Control cables Inc. The cost was only 30.00 plus shipping which was way less than Inline tube. I had a sample of my original one that they used for measurements.
1967 F-100 4x4 custom cab.
Another 67 F-100 4x4 custom cab.
2016 F-150 Eco-Boost 2.7 liter. (It will smoke the tires!)
1972 F-350 Sport Custom cab & chassis.
1972 F-250 Explorer Special, Camper Special.
1971 F-100 custom. 302, C-4, p.s. p.b. factory 65 amp alternator with transistorized voltage regulator.
I did get lucky with my vintage ford parts guy here in denver. He just happened to have one, haven't gotten around to installing it yet. Just rebuilt the 205 tcase to replace the 24 with.
My parts book shows 68 up F-250 4x4 from serial # D54,001 uses a C7TZ-2853-L. Shows to be 87 and 5/16" long. I ran a search on a locator site and there doesn't show to be any available anywhere.
If you can't find one, I think I have a 71 or 72 model F-250 4x4 that should have the correct used one on it. Let me know.
Just shipped my cables to bruin brakes. Getting front and both rear made for my 72 f250 4x4 with heavy duty brakes. Once they match mine, duplicates will be available on thier site.
1972 f250 4x4 390 4speed
While rebuilding my heavy duty rear drum brakes on my '68 F-250, one of the parking brake cables was completely frozen. It was on this forum that I found Bruin. I shipped them an old cable which Greg (the Bruin guy) used to fab replacement cables for my project. Unless you're doing a $50k+ restoration, I do recommend these guys. The new cables looked great and work perfectly.
Tony
Tony
