The Ranger XLT @ Holley Ford Fest 2024 in Bowling Green KY After Missing HRPT 2019 and Power Tour 2021
71cc
Re: The Ranger XLT Gets Ready For Power Tour 2019
Post by 71cc »
Afaik these trucks all came with single row sealed roller bearings . The 9-3/8" axle 3600# had 31 spline bigger axle with sealed double row bearings, now $$$ obsolete. The A20 came in 77-79 lincoln disc rears and later. Most 77 and up everything with new pattern rear even with drums.
DuckRyder
Post by DuckRyder »
Thanks man, hopefully it won’t be too long until I’m putting the Axle in...
Seems fairly obvious a lot of the list is getting put off until 2020 though Mrs DuckRyder is making noises about wanting a seat if she’s spending 9 days in the truck....
DuckRyder
Post by DuckRyder »
Well I got some cleaning done, will endeavor to paint the housing and backing plates during the week if it stays warm enough.
What we are working on.
Obviously someone was painting on the chunk, from what I recall they are supposed to be basically the color of red oxide primer. Also runs in the black. Looks like it had some grease pen markings at some point,
Gear number, Marked FoMoCo USA D2AW 4210 B triangle 2 (this should be a 3.50 gear.)
I think I got an apprentice welder for 2 of the welds, 2 of the other ones are very nice. I suppose it could be a repair but the filth was evenly distributed.
Cleaned up.
Chunk cleaned up, I dried everything and coated the gears and bearings with WD40 to stop flash rusting.
DuckRyder
Post by DuckRyder »
Guess I have to go count teeth on the ring and pinion. I’m going to be pissed if it isn’t a 3.50:1 (unless it is a 3.70 or 3.90)...
DuckRyder
Post by DuckRyder »
Got the housing painted, it isn’t my best work but it will do...
popeyes71
Post by popeyes71 »
Its going to look good!
-Popeye-
1971 F-250 4x4 Highboy
DuckRyder
Post by DuckRyder »
I do hope so Popeyes
I count 12 pinion / 39 ring so that makes it 3.25:1 If I am not mistaken. Guess this explains why it had been out, someone before me changed it from 3.50:1 to 3.25:1.
I’m displeased about this and trying to talk myself out of ordering a 3.70:1 or 3.89:1 gear. :help:
DuckRyder
Post by DuckRyder »
The housing ready for paint. (last week)
Got a little done today.
I know it is too glossy and the oil slinger is not supposed to be painted, but it is not a K-Code Mustang so I did not worry a lot about it. Since this is going to be a driver I actually plan to coat everything with a waxy coating when it is all finished.
The Axle bearings were supposed to arrive today, but did not.
I think I am going to try the present gear.
DuckRyder
Post by DuckRyder »
Axle bearings came...
Ranchero50
Post by Ranchero50 »
Personally I think you'll not notice the 3.25's as far as performance goes and you'll love them for longer drives. Heck, if you pack two sets of wheels and tires, one tall for the road and one short for the track you'll have the best of both worlds. Figure the tire height difference from 3.00 to 3.25 to 3.50 to 4.11 and go from there. Probably a 31" for the road and 24-26" for the track. You'll want the track tire short since they grow with speed. Figure out what will hold the torque off the line (another benefit of the 3.25's) and go with it.
Wheels and tires are probably cheaper than an OD unit.
DuckRyder
Post by DuckRyder »
I think you are right, the current tires are about 28” so I will probably be happier with the 3.25 on this little jaunt... I can rethink it with a tire change later.
Manny
Post by Manny »
Looking good gonna have to be careful not to scratch that 9 chunk here. So what is the plan on it just swapping in the tru trac? and freshen up? :?
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
DuckRyder
Post by DuckRyder »
Yeah man, it looks better in pictures than in person, but I figured it might get some um character working on it...
Yep, I’m figuring just swap the bearings and tru track, at least to me the gear looks to be in good shape. I can try to take some pictures if you like, I guess if we get into it and need something I can run down to Summit...
Manny
Post by Manny »
Sounds good no issue on that all new bearings and such is not a problem It's a 28 spline and such?
DuckRyder
Post by DuckRyder »
Yep it is a 28 spline. Bronco graveyard assured me we had the correct bearings for the tru trac.
