Forest Service Truck Coyote Swap
Fordkid68
Re: Forest Service Truck Coyote Swap
Post by Fordkid68 »
Nice welds, it looks factory!!
Adam
My first truck,
^^Build Thread^^
(no other projects, YET!)
miller
Post by miller »
Thanks Adam. After a busy two weeks at work finally have some time for the truck. Finished drivers rocker and kick panel repair.
miller
Post by miller »
Repaired drivers rocker where cross brace is secured and installed new driver cross brace repair. Still need to clean it up.
miller
Post by miller »
Drivers floor. Not sure where to cut this one. It appears to be short on the left side by 3/4". Not sure how much massaging the corners will get me on that side. Also I no longer need the hole in the upper right so thinking of doing the whole thing. I think all panels I can buy will have some issue. Going to think about this for a couple of days and do it on the weekend.
hfdco4
Post by hfdco4 »
Great work. As for the patch panels, there is always adjustments to be made.
:fr: FE390PC
Fordkid68
Post by Fordkid68 »
Definitely try to cut off those bumpy edges on the floor pan, That one will really take some figuring.
Keep it up and soon you'll never know the rust existed!!
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
I agree. My plan is to cut it about 1/2” above the floor and hopefully should be able to straighten it out a bit. It looks like there are some better panels out there so if it’s an awful fit that’s an option.
miller
Post by miller »
Not that bad of a fit for $40 bucks!
Fordkid68
Post by Fordkid68 »
Wow! That fits great. What brand are those?
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
Tabco is the brand. I got it trimmed and tac welded in place. Very happy with how this went I was expecting a lot worse. I would buy this pan again. Still a lot of welding and grinding to do!
Fordkid68
Post by Fordkid68 »
Looking good! That fits better than the one I got from DC. Unfortunately it was made in Taiwan. :cuss:
Adam
My first truck,
^^Build Thread^^
miller
Post by miller »
Welded in and cleaned up bottom. Still need to grind and clean up inside.
miller
Post by miller »
Fitted drivers front cab mount. Epoxy primed the floor and will install tomorrow.
jimmy828
Post by jimmy828 »
Looking good. Nice work too. :thup: :thup:
67mann
Post by 67mann »
:rock: :bow:
I've had enough and I'm not alone
http://s267.photobucket.com/albums/ii304/67mann/
