pic's on 67 p/s conv
- Wes
re: pic's on 67 p/s conv
Well Crew,
Everything came to screeching halt. UPS lost one of my front springs, new one on back order. So I had time to trim my back trees. While doing so, the ladder slipped and drop me @ 18', I landed on my right leg shattering my ankle. So will be sometime before I get back to getting the truck on the road. Hopefully I'll be able to get the boys on it when all my parts get in.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- 460 crew
- Wes
Thanks for your offer to help. So far I 1 front spring and the hardware kit. the other 3 springs are yet to be shipped. Lol ya I have Skyjacker on speed dial have called them and Summit several time each. Skyjacker sent instructions for 1980 up seems they don't have correct year instructions.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- Wes
I got 2 rear springs last week the remaining missing front spring might be delivered the 1st or second week in June. The boys got rears hung had to oder shackle bushing from LMC, Going today to get a longer rear brake hose made. Will have some pics soon
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- 460 crew
Nice
Bites that they have taken so long with the springs.
Skyjacker carries a rear brake line, you could get from 4 wheel parts or national tire and wheel online.
- Wes
There is a surplus outfit near me that makes up dot stainless braided lines. I priced Skyjackers front lines $120.00, I went to G&J they made them while I waited for $55.00. I also got the Heim joints, and weld in bungs for the drag link there.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- 460 crew
Did they have the fitting/ block deal that bolts to the axle and has the inlet connected to it and 2 side ports like the original? If so I'll send you some cash to grab another line if you are near there again. no place in town here has such a thing so I have a cheezy T there held in place by the lines.
- Wes
Yeah this place is great I love doing business there. I got the hose made. Cost $20.47 took 5 mins to make. LOl I waited longer to be served then it took to make hose.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- Wes
Just a little more info for people considering the Skyjacker lift kit. The kit is not for our bumps, is for Dents, the hardware kit came w/ u bolts front and rear; poly bushing and sleeves, for the front springs. The rear u bolts will not simply replace the old stock.
I reused my old u bolts.
Here is a side by side photo.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
- jeepermc
All it takes to make the rear u-bolts work is the spring plates that go above the springs off a 2x or later bumpside.... Then you don't have the threads hanging down waiting to be damaged and not running 35 or so year old u-bolts still.....
1952 CJ-3A- 289cid, NP435
1969 F-250 4X4- 410cid, NP435, Dana 24-44-60LS , 4", 36's
1975 F-250-Ranger XLT 4X4- 390cid, NP435, NP205, 44F, 60 rear
1987 Mustang GT
New addition- 1997 F-350 PSD std. cab 4x4
I really have a problem...............
1987 Mustang GT
Round U-bolts are a lot weaker than square with the cast plate on the bottom. They seam to hold up to a lot more abuse. U-bolts aren't torque to yeild or anything, There's nothing really wrong with re-using them if they're in good shape.
I've had new made in china U-bolts that come with lift kits break/stretch where 40 year old beat down rusty ones have held up no problem.
If U-bolts are a concern, your best bet is to have some correct ones made at a spring shop. I always up the size to 5/8". The light duty F-250 4x4's came with 9/16" U-bolts the 7700 GVW trucks had 5/8".
- Wes
when we swapped out the front axle, had to cut the u bolts I ordered new ones from a local 4x4 store. Paid @ $50.00 for the 4 of them I hope there not chinese. Have to go back and ask.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
Typically spring shops are a better source for spring hardware than a 4x4 store. Spring shops that work on big truck stuff and have all the right tools and experience usually get you a better product. Thier U-bolts are just lengths of rod that they bend to your specs in a specially made brake. The bolts I've gotten locally always have manufacturer names and material specs stamped in them, that's piece of mind for me.
- 460 crew
If they don't work out I think I have a set in my storage unit.
- Wes
Come to think of it Dustin, I kinda remember a Canadian Maple leaf sticker on each one. I feel better now.
Wes
67 F250 High boy
69 Bronco
67 F250 High boy
69 Bronco
