Valve cover gasket tip...
Re: Valve cover gasket tip...
Because cork gaskets suck.
- 1972hiboy
I put cork gaskets on dry now. the idea being that oil would soak into them and cause them to swell making a better seal. I always used to put sealer on them and they did end up leaking quite badly. The last 390 I did my machinist told me to put it on dry so I did. They have held up very well.
Rich
Dont eat yellow snow.....
Here is a tip. Throw the cork gaskets in the trash! Spend a few extra buks on some steel reinforced rubber gaskets and save yourself some time and hassle as well. They are also reusable. Best thing I did in a long while and they won't leak.
Build thread:
http://www.ford-trucks.com/forums/12052 ... build.html
I didnt use any. Also i wish i saw those clips earlier. I know i have some large ones sitting around. Dang. Good tip.
D
D
2008 bmw 528i
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
2014 audi tt Quatro s
Braaaaap!
1967 ford f100
2014 vw tiguan
2016 kawasaki 250f
2015 KTM rc390
Braaaaap!
Something else I also do when changing oil pan or valve cover gaskets is lay the edge of them on a piece of metal and tap around the holes to make sure the area around them is flat. When I worked in a local garage you wouldn't believe how many I had to do that to because they were leaking and someone overtightened them thinking that would stop the leak and bent the edge of the holes down........
1997 Honda CBR 900RR
Same idea, different approach---- I've always kept a pack of clothespins around the shop. Versatile, low clamp pressure, handy and ............Dirt cheap! I just keep them clipped to the card they came on hung on the pegboard.
Your humble Rural Engineer-
Mike Burgess
Albert, KS
Mike Burgess
Albert, KS
- HIO Silver
The problem with cork valve cover gaskets is the person installing them.
It's a matter of bad technique and poor attention to detail than the material itself.
70 F100 LB 2WD, 360FE, E-Street EFI, TKO-500, 76K original miles.. follow my rebuild: The Lo-Buck Bumpside
71 F250 LB, 2WD, 360FE, T18, PS, PB, D60 with 4.11s
73 F100 SB 4WD, 390FE, NP435, +4 on 35s
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
