It was a nice day today, temps. in the 40's, so I took my 72 f250 4x4 out for a ride.
Yesterday I put a mirror on the passenger door, today I put the cover on him and put him to bed for the winter.
I hope spring comes early!
- HIO Silver
Installed the ECU and wiring harness for the Edelbrock E-Street EFI.
70 F100 LB 2WD, 360FE, E-Street EFI, TKO-500, 76K original miles.. follow my rebuild: The Lo-Buck Bumpside
71 F250 LB, 2WD, 360FE, T18, PS, PB, D60 with 4.11s
73 F100 SB 4WD, 390FE, NP435, +4 on 35s
01 Ferrari 360 Spider F1
01 F150 SuperCrew Lariat 4WD
01 PT Cruiser Limited (DD)
68 Mustang
65 Mustang
68 Mustang
65 Mustang
Not so much what Idid to my truck today but what I got for it. on Sat. I picked up a running 390 complete from carb to tranny.It has a Holley carb and a 390 streetmaster edelbrock intake. I started pulling it apart on Sat afternoon.When I got the intake off and took out the oil vail plate I found a broken rod. Apperently at some point this engine braoke a rod and had a new one put in but the old one was left in the oil valley.I am going to rebuild this 390 while leaving the 360 in the truck and them swap them out when I am all done. I donr know if I am going to use the C6 or not. I currently have the NP435. Have toyed with the idea of having an automatic but am unsure if I want to do it. Any ideas? Pros/cons of going automatic over the stock 4 speed?
Russ Stanley
68 F250 ( ol' Grand Dad)
71 F100.( Old Blue)
65 Valiant Wagon (Gone but not forgotten)
2007 PowerStroke(The Golden Goose)
71 F100.( Old Blue)
- huskerrush
passed inspection. good for another year. $14.50.
You can fight without ever winning, but never win without a fight.
Painted the rear drums with dark Ford blue engine paint. Hope to get the rear brakes rebuilt next spring.
- jimmy828
NOTHING!!!
Bought a locking gas cap
bucket seats out 87 xlt lariat bench in
my tilt column is out of a 78 bronco & i needed a ragjoint to fit it
turns out 78-79 tilt columns are different from everything else...and the ragjoints are obsolete..so after figuring out the spline count (harder to do with the flat spot on the shaft) i'm ordering a u joint and calling it good nuff
FYI: 78-79 Tilt column - 3/4" shaft,36 splines
ford steering box - same
u joint should be 2-1/2 - 3" long overall
- still got my first first car 20+yrs later : 69 f100 sorta kinda pretending its a Mercury M100 w/a 70 f350 sport custom cab (factory buckets) 67 grille with 69 ranger cooneyes 68 merc box and hood,some supercool fiberglass fenders i scored way back when, 76 f150 disc brake frontend..currently running a 90 5.0HO 4bbl/c4 auto & 3.50 posi...originally a 360/c6 f100 Ranger with dealer added towpack (incl. kelsey hays trailer brake),boxside toolbox,behind the seat stowage & belly tank...only original parts left on 'er are the frame,rear end,rear springs,and rear bumper...
- HOWDY69
I worked on the bumps younger sister the 71 Mach 1.
http://www.7173mustangs.com/thread-nick ... g-as-we-go
69 F250, FE Specialties 410, CJ Valves, RPM Intake, Holley 4150,......10 Smiles per gallon
71 Clydesdale in many pieces; 302 roller motor waiting impatiently
- SevNT2Bump
Lately, I've been getting back into my truck. Today, I flushed all the old transmission fluid out and topped it off with new. I can't say that it had been changed before. No leaks and it is shifting proper
Ken
72' F250 Custom 2wd 360 C6 auto
99' GMC 1 ton dually flatbed 454
07' Ford Ranger 2wd 4.0 Sport
- 68FORDJBM
I noticed that my passengers were not opening the doors on my truck with as much care as I would and are chipping the new paint. Quick and easy Solution: I cut one of those cheap plastic report binders in half and slipped them over the edges on the doors. I wasn't smart enough to take pictures but can if anyone is interested
- Norse
I married the woman who thought it was a great idea to buy our 1970 F-250 and fix it up.
Norse
Livermore, Ca
2008 Triumph Rocket III Touring "Trixie"
1995 F-350 ex-ambulance (aka; "The Rig")
1970 F-250 "The Truck"
Livermore, Ca
Norse wrote:I married the woman who thought it was a great idea to buy our 1970 F-250 and fix it up.
