The only part of the I beam that has changed is the end, the pitman arms are still in the same position.GT-Racer wrote:you may need A drop down pitman arm. Like comes in most bigger left kits. That may re allign your steering linkage. I think.
upside down i beam?
- Heavenlyfire
Re: re: upside down i beam?
- boots
but if you get a lift off this then you may need a drop pitman arm, dont want to bump steer
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- 460 crew
These guys have drop pitman arms for fords also one that dosen't have 90degree settings but any position u want. http://bulletproofsteering.com/main.html
- boots
with my 4" coils on my truck it still looks like I will not need a drop pitman arm, but you may need one.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Heavenlyfire
HELP!! I need information now. Hit a road block. In order to make this work I am going to have to flip the spindle upside down. Is the pin that holds the spindle in tapered? If it is then I am sunk and will most likely have to put it back the other way.
- GT-Racer
Thats what I meant. I think.boots wrote:but if you get a lift off this then you may need a drop pitman arm, dont want to bump steer
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
- Heavenlyfire
UPDATE!!! I just flipped one spindle and that throws the allignment way out of whack. So, I checked the other side and the allignment looks good but now the brake backing plate has to go on upside down. Not too much of a problem. This will be the first fabrication on any of it. I am going to run a steel brake line from the wheel cylinder, which is on the bottom now, around the spindle and to the to to connect with the rubber line. Getting closer.
- Heavenlyfire
Just got back from the local pull a part with 2 great looking break lines that are perfect for the extention that I need.
Bad news, now I gotta go to work
. Oh well I will try to get this project done in the morning.
- Heavenlyfire
- rjewkes
Well, Heavenly it was fun while you tried it. And i think we all learned something we did not know. Or I know i did at least.
- Heavenlyfire
Was just putting my front end back into my 250 and couldn't get the brake backing plate to go on one side. Stepped back and took a look at it and I had put one side on upside down.
Didn't I just say that didn't work
- boots
ahhh im so sad becuase it didnt work.
well was worth a try though. I just got my brackets in the mail today after being lasercut. They are gonna be on my truck July 2nd, ill post pictures then.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- Heavenlyfire
Wife made me take a picture of it to show you guys.Heavenlyfire wrote:Was just putting my front end back into my 250 and couldn't get the brake backing plate to go on one side. Stepped back and took a look at it and I had put one side on upside down.Didn't I just say that didn't work
- Joe Kriston
Geez,I hope you weren't doing all that work outside...Wasn't it like 110 degrees today?
This is the point...I'm....talking about everybody! I'm talking about form! I'm talking about content! I'm talking about interrelationships! I'm talking about God, the devil, hell, heaven!!!! Do you understand???? Finally!!!!
- Heavenlyfire
Yep in the carport for the last week, what a drag
. where are you in AZ
