rear lights.
rear lights.
hello, i was wondering if anyone has had this problem: I have a left hand turn signal out, the lh brake light does not work or the lh 4 way flasher the regular lights work fine and the right hand side all works fine. the bulbs are good. if any suggestions i would love to hear them if not i am sure i will figure it out sooner or later.
1969 FORD F250 4X4
re: rear lights.
I'd double-check that bulb. The turn signal and brake light use the same filament (in the dual-filament bulb), so I'd be willing to bet it's looking good when it's really not. Hook up a multimeter to it and check for continuity across the filament, or replace it with a known good bulb.
If the bulb does check out, then make sure the bulb socket is clean, and then start following that wire up to see where it's broken.
- rjewkes
also on this model the light housing is the ground. Double check your grounds if all else checks out. you may need to tighten the big screws holding the housing in.
- bluef250
