first off- for wiring an entire duraspark ignition system for the first time, i think i did a good job. getting my engine to fire first try.
i put in a new starter sylenoid because the old one didn't work. (or so i thought)
so i wired everything up, plugged everything in. i went to turn the key, and NOTHING! so i just was like, hmmm. i turned the key to the off position, and i figured, that maybe the wires were switched around from the getgo. i go in my truck put the truck in the 'on' position and it started cranking all by it's self. my uncle told me that the it was the ignition switch (where you put you key in) and it was broken or something.
so i ended up taking the wire off that goes to the starter, and turning on the starter by putting it ti the positive termanal on the battery.(i did this because i really wanted to hear it run tonight)
so i really don't want to have to get out of my truck to turn my truck on, how could i have gone wrong with something..
it is not the NSS because i tired it back temporarly. while i'm troubleshooting through all of this.
any advise helps.
thanks in advance!
