whats the b termanal on my starter solenoid do? should it be hooked up?
right now i have it so that there's the S termanal is switched on and off by a switch in my truck. and my B termanal isn't hooked up.
good? bad? doesn't matter?
B termanal
- splavin90
B termanal
69 F100 81' 302 / 73' fmx
I'd rather go hunting with Dick Cheney than go driving with Kennedy
- 68F250
re: B termanal
"B"? I thought it was an "I".
Barry
- 67F250CS
re: B termanal
http://www.fordification.com/wiring.htm
Take a look at the wiring harness photos that Keith has archived for us.
They always have answered my questions.
1967 F250 Camper Special
10MPG with key off, in neutral and going downhill!
- splavin90
re: B termanal
here's what i mean-
http://img.photobucket.com/albums/v113/ ... /relay.jpg
the wire and termanal i have circled, what is it, and should i have it hooked up?
- 68F250
re: B termanal
Yeah, that's the brown wire.
It's the ignition resistor bypass so the coil gets full battery voltage when the engine cranks over.
Barry
