My question is about connecting the speedo and tach. If you look at the back view of the instruement cluster, you'll see a part, which extends from the speedo gauge in the center of the picture. The part that is connected/screwed to the speedo looks like it has a small motor built into it with 2 black leads wired to it.
I find this confusing, and I am wondering if that part attached to the speedo really should be connected to the tach? Wouldn't a mechanical speedo cable connect directly to the speedo gauge? Also, it would make more sense if that small motor on the part is used to turn the tach needle, not the speedo... right?
Who out there has experience installing a F-600 instrument cluster in their bumpside?
Your help is much appreciated.
