OK, here's another one for you all. All trucks use these. The washers are (should be) a give-away, since AFAIK there's only one spot that uses this style. What are they used for?
um holding that thing together!!!!!FORDification wrote:OK, here's another one for you all. All trucks use these. The washers are (should be) a give-away, since AFAIK there's only one spot that uses this style. What are they used for?
Scratch that, looks like washers and bolts that hold the steering shaft bracket in line.JWW wrote:They look like cab mount washers.
Yep, you got it! These are the bolts and cup washers that hold the steering column mounting bracket to the outer side of the firewall.JWW wrote:...looks like washers and bolts that hold the steering shaft bracket in line.
