Cutting and the right tool
Discuss your workshop and related equipment
72stepside
Post by 72stepside »
Last night I had to grind some carriage bolt heads because the nut was fused to the bolt. I used my angle grinder which took a little while (bed bolts are HARD). I got to thinking more about future cutting needs with bolts, rusted body panels and such.
I've never used one of these type of cut-off tools...
http://www.sears.com/shc/s/p_10153_1260 ... rd=cut+off
Are these any good for cutting patch panels or cutting off bolts? Do they bind up and try to take off with you? I've never used one and wondered if they are worth the money. I figured I'd try a Harbor Freight model first.
What'cha think?
Chris
72 F100 Stepside w/ 78 300 CID
Hedman Headers
Disc Brakes
Power Steering with 3 STILL on the tree
Comfy Crown Vic Seats
71 F250 PS, PB, AC, Auto, 390
Loooong way to go on this one!
1971fordcustom
re: Cutting and the right tool
Post by 1971fordcustom »
On the grinder what type of wheel was you useing!! I use angle grinders all the time! But I use the really thin cuting wheels. It don't take any time at all!!!
One of my friends uses the angle grinders on body parts and it does just fine!!
It woud be nice to have what your looking at.
http://s205.photobucket.com/albums/bb31 ... d%20F-100/
1971 F-100 Explorer Special custom
1971 F-350 Flatbed
1966 Ford Galaxie!
1966 Ford F-250 4x4
1960 Ford F-750 FireTruck
1960 Gmc 6000 FireTruck
1962 IH R-185 Firetruck
1959 Ford Custom 300
1940 Ford Truck
oldschoolrods
Post by oldschoolrods »
I've used them before, if you have the air available they're alright, the straight part does come in handy for things a right angle just won't fit into.
1969 Ford F250 Custom Cab 360/C6 - currently under de-construction
72stepside
Yeah, I was using a grinding wheel, not a cutting wheel which is a bit thinner. I'll pick up one tonight and get the rest of the bed bolts cut off tomorrow night.
Chris
Hedman Headers
Disc Brakes
hardtailjohn
Post by hardtailjohn »
I've had one made by SnapOn for about 15 years now, and it's about ready to be sent in for rebuild. They're really handy, but as Keith said... the foreign ones sometimes don't have alot of power. I use it for cutting tubing, panels, bolts, and alot of other stuff... by all means, spend a few dollars more and get a good one that has some torque to it, and you'll love it!!
John
72stepside
I got the thin cutting wheel for my Dewalt Angle Grinder. It cut like a champ. No need to buy another tool. More money for the truck !!!!! :clap:
Chris
Hedman Headers
Disc Brakes
Leadfoot
Post by Leadfoot »
I like the torch for bolts and such. why play with little spinning tools then you can burn it off. :2cents:
also for body work a quick cut is the way, but if cash is a problem even a cheep circular saw and a metal disk will beat a die grinder any day.
WHAT ?
flyboy2610
Post by flyboy2610 »
http://www.milwaukeetool.com/webapp/wcs ... 170_192137
Best grinder I've owned out of the three I've had.
BobbyFord
Post by BobbyFord »
I've got two of the SnapOn ones and they work great. Buy quality discs and wear eye protection; those little suckers toss chunks off if they're not quality discs or if they crack.
1971ford
Post by 1971ford »
im talking about the actual cut-off grinders. the littly tiny tube bodies with the disk on the end. mine is working really nice for $15 (or whatever it was )
but it does say to run it at a certain psi like 90psi, i have the output on my compressor at whatever is in the tank which goes up to 160. probably a pretty bad habit :doh:
but starting a week ago i have been turning the output down to help the compressor so it doesnt have to work as much
-Ryan
71PA_Highboy
Post by 71PA_Highboy »
I dumped all my air grinders (except 1) in favor of the electric 4.5". The only reason I keep one of the air around is areas where the fit is just too tight for the electric.
Good luck with whatever you choose.
Eric
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 F250 4x4 (71) - OB - 360, NP435, D24, HPD60 4.10, D60,
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
