Sorry I haven't been on here in a while to update this, been busy with work and women problems
So the front end is back on the ground now.
Ordered and received new pre bent steel brake lines and all new parking brake cables from NPD.
Then pulled the rear end out. Then realized I need one new brake drum, decided to replace bolth. None of the parts stores here seem to have them so I Ordered 2 from LMC Truck. Also Ordered some POR-15, (six pack) Marine Clean, and Metal prep.
Also bought a new rubber brake line for the rear end and a new master cylinder. Getting funds up for a new brake booster and new rear shocks.
Went to install the pre bent brake lines from NPD. Everything seems to fit cept the 2 front lines. The ones that go to the drivers side and passenger side drums. They are bolth too short.
But what I Ordered is for a 72 F100 2 wheel drive with power drums....so Idk whats up, will be calling customer service as soon as I get a chance.
Will be posting up pictures Sunday.
Hopefully Ill have the rear end back in, and the parking brake cables installed by Monday night.
Then I need to find a drive shaft, radiator, and shift linkage, and a x member and start ordering parts for the 460
