Upgrade from points?
- TRUCKRODDER
My truck has points which I really don't know much about. What is a good upgrade . I know Chevrolet you switch to a hei , kinda new to Fords.
"You can't polish a turd!". (Quote from my Grandad.)
- Joshpow
Re: Upgrade from points?
Ignitor and Ignitor II are good under cap replacements for points. They will fit your existing distributor. You can also use a good high volt coil to help. I got an Ignitor in mine. I love it. No trouble or adjustment at all since I put it in.
Josh
72 F-100 Ranger XLT SWB
71 F-100 Custom SWB
67 F-350 Dually Dump
02 F-250 Stroke
http://www.cardomain.com/ride/2972100
71 F-100 Custom SWB
02 F-250 Stroke
- willowbilly3
I am plenty happy with the petronix. HEI style distributors are available for many Fords. Davis Unified is probably the best from what I hear.
- TRUCKRODDER
Are the ignitor and pertronix available at a parts house or online? What is the difference in the two? I will do some research soon when I can.
- 390F100
Pertronix is the company that makes the ignitor. If you go to any speed shop they should carry the Pertronix Ignitor II, buy that along with the Flamethrower Coil that they make as well. The install takes literally under 10 minutes and is outstanding. You should expect to pay around 130.00 for both the Ignitor II points eliminator kit and the Flamethrower coil. It is a fool proof install and is well worth the money. The only issue I had was I got a defective part, but I warrantied it out and now she purrs like a kitten. I give it
and a
"There's no replacement for displacement"
1968 Ford F-100 2wd 390FE
1993 Toyota P/U 22RE
2001 Toyota Camry 2.2
2004 Toyota Solara 2.4
2007 Yamaha Vstar 650 Custom
2007 Suzuki S40 650
2007 Suzuki S40 650
- TRUCKRODDER
I went to O'reilly earlier to get a fuel filter and they had the ignitor for around $ 90.00 . I will shop around and get an Ignitor II and a coil soon. Thanks guys!
- willowbilly3
I was going to say O'rielly's had them. I did not do the coild upgrade when I switched mine.
Pertronix is the best bang for the buck. I bought mine at Knechts (for less than 100 bucks) at the same time I bought my intake and carb. I am no expert at setting up points, but I noticed more of a change with the Pertronix than I did with the new intake and Performer carb. Just my two cents.
- Dragon
You got burned!!! They don't cost that much here at any store. My last Accel points eliminator cost me 45. If you saw more change from the points eliminator then you had a seriously out of tune truckelmitcheristo wrote:Pertronix is the best bang for the buck. I bought mine at Knechts (for less than 100 bucks) at the same time I bought my intake and carb. I am no expert at setting up points, but I noticed more of a change with the Pertronix than I did with the new intake and Performer carb. Just my two cents.
Old Fords Rule
Was a Ford Service Tech
71 F250 with Shell Car 390 NP435 Dana 60 3.73s, PS, PB, 750 EC VS Holley Accel Points Eliminator.
98 Volvo S70 2.4T Auto
71 Service manuals Volumes 1,2,3 and 4 So ask away.
My Gallery
Spark test
My Gallery
Spark test
