Wheel Help
- boots
Wheel Help
Im searching for new tires and wheels for my 67 f100 2WD. Im planning to get 33x12.50 or 33x13.50 on 15x10. What is the bolt pattern on my truck? 5 on 5?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
69 f100- Parts truck
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- morganater
re: Wheel Help
5x5.5
1969 f100 swb ranger 460 - parting out
1968 f100 swb 429 - decking out
94 Jeep I6 Back-up vehicle
reppin' AK
reppin' AK
- boots
re: Wheel Help
thanks for the help
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- wekelm
re: Wheel Help
I had 33x12.50 on the front of my F100 when I bought it. I kept hearing a funny noise when i turned the wheels lock to lock. Turned out the tires were rubbing on the radius arms. Make sure you check the clearance before you buy. I have 31X10.5's on now no problems.
Bill K.
'71 F100 custom
'89 Probe LX
U.S. Army Retired
'71 F100 custom
'89 Probe LX
U.S. Army Retired
- boots
re: Wheel Help
ok, thanks for the heads up
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
- moore89
re: Wheel Help
I have tires close to a 33x13.50 (315/70/15) on 15x10.5 wheels in the rear of my 67 2WD race truck. Not sure on the offset of the wheels but I know you really need to be right on with that to make tires that big fit. The tires will kiss the wheel wells if I hit a bump hard. Here's a pic.
67 f100 2wd LWB (go fast truck). 460/C6 lots of lope and gobs of torque (under construction again) 13.06 in the 1/4mi (with the old less built motor).
2 Thunderbird Supercoupes (a 1990 35th anny., and a 1991 modded pushing 15 lbs of boost)
1989 Ford Taurus SHO 5spd
re: Wheel Help
I hope you have power steering if these are going up front.
- boots
re: Wheel Help
thanks for the info, i will have no problem clearing 33", my truck is lifted 4" so its ready for some new tires.
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
re: Wheel Help
I've got 295/50/15 tires on 15X10 wheels front and back with manual steering. Tread width is 12" and they don't rub. Believe it or not, they are easier to turn than the stockers were.
1968 F-100 2wd Short bed style side
-302,C4,3.50 9"
1977 F-150 Ranger XLT 2wd Long bed
-400M,C6,3.25 9"
1981 F-100 2wd Long bed
-460,C6, 3.? 9"
-302,C4,3.50 9"
-400M,C6,3.25 9"
-460,C6, 3.? 9"
- boots
re: Wheel Help
is 295/50/15 around 33"?
Ethan
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
390/3spd/9"
68 f250 - 390/np435
Raised d24
'79 dana 60 front
welded 60 rear
buildup in progress
re: Wheel Help
Nope, more like 26" tall. They fit fine width wise. Don't rub the radius arms.
-302,C4,3.50 9"
-400M,C6,3.25 9"
-460,C6, 3.? 9"
-302,C4,3.50 9"
-400M,C6,3.25 9"
-460,C6, 3.? 9"
- GT-Racer
Re: re: Wheel Help
I'd like to see some pics of that. Must look pretty kool.68F100 wrote:I've got 295/50/15 tires on 15X10 wheels front and back with manual steering. Tread width is 12" and they don't rub. Believe it or not, they are easier to turn than the stockers were.
'67 F100 2wd shortbed - Beginning restoration.
351w, 5-speed, 3:70 gears (someday)
Drivin' a Chevy is Kinda Like wipin' before you poop, it just don't make no sense....
re: Wheel Help
-302,C4,3.50 9"
-400M,C6,3.25 9"
-460,C6, 3.? 9"
-302,C4,3.50 9"
-400M,C6,3.25 9"
-460,C6, 3.? 9"
- granitestate68
re: Wheel Help
68F100,
Do you have a lift on that? I'm looking for really wide tires in the back, probably 50's with maybe 60's or 70's up front. What back spacing do you have? I'm thinking about getting the American racing smoothies. Any input from anybody?
Any info would help.
Lee
Lee
http://www.fordification.com/galleries/ ... p?pos=-550
1996 F250 Slightly lifted 7.3L Diesel
1961 Falcon Ranchero 144 Inline 6
re: Wheel Help
No lift. Stock 2wd suspension. I'm not sure what backspacing. If someone wanted to tell me how to measure it I could.
-302,C4,3.50 9"
-400M,C6,3.25 9"
-460,C6, 3.? 9"
-302,C4,3.50 9"
-400M,C6,3.25 9"
-460,C6, 3.? 9"
