Comments...
1. I have a DOVE-A 429 virgin block. (4U stamped on the crank)
2. I have a 351/400 bellhousing and spacer plate.
3. The chassis is bare with no body sheet metal at all on it. (body swap when the chassis is done)
4. Ive heard a lot off bad things about L&L's mounts and I trust my own work over a company worrying about there checkbook.
5. Oh, and my truck is fitted for an FE motor.
Questions...
1. In building my own mounts, do I need to worry about the 429/heads/valve covers coming in contact with anything? (Firewall, Brake booster)
2. If so how far forward do you tipicly have to move a 385-series big block? I would like to retain the stock location of the motor/trany/transfercase. (married-up, built my own crossmember)
3. Are these 385-series motors dependable/durable or is it even worth the effort/cost?
Thank you for your time and I appreciate any input one way or the other.
