Top side creeper
Discuss your workshop and related equipment
cdeal28078
Top side creeper
Post by cdeal28078 »
I should have searched but I never have any luck with it.
Has anybody on here made a top side creeper?
http://base0.googlehosted.com/base_medi ... 5c94&hl=en
I have 3 bad discs in my back and like the way these things look.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
Re: Top side creeper
i've seen homemade step stools similar to that.
ximy
Post by ximy »
Here's a pretty cool top side creeper... I imagine it is a custom made job though.
1967 f250 428
Heathcliff68f100
Post by Heathcliff68f100 »
Dont get one with wheels, we had one at the shop i used to work at and every time you put any pressure on a bolt, you pushed yourself backwards, imho they arent worth it
1989 dodge b250 van, 239 v6 blown a904 tranny RIP
1968 ford f100 lwb l6 240 c6 tranny
BobbyFord
Post by BobbyFord »
We had one at a shop where I worked that had spring-loaded wheels; if there was no weight on it you could roll it all over the place, as soon as you start up the steps, your weight would cause the stationary feet to move past the wheels.
knuklz88
Post by knuklz88 »
i work on diesels at a ford shop and got one through rotunda tech tool program it has wheel locks and is adjustable
FreakysFords
Post by FreakysFords »
knuklz88 wrote:i work on diesels at a ford shop and got one through rotunda tech tool program it has wheel locks and is adjustable
We had the same one. It was good enough, but it was also a bit of a pain. I ended up making my own version with a wider top platform, heavier gauge steel easier socketed uprights (for folding up and stowing, our shop's storage was TINY). Later we added a socketed top over the ladder to add a "gantry arm" that we used with a canvas sling for odd jobs.
Wish I knew what happened to that thing when the dealership closed. I'm actually looking to make another for the tractor shop.
DIXONBOY
Post by DIXONBOY »
KNIKLZ88 CHECK YOUR PM!!
hazelnut
Post by hazelnut »
I wish i had one yesterday when i changed the injectors and glow plugs in my 06 superduty, my ribs are sore from laying accross the radiator support and engine. now i see why ford lifts the cab off the chassie.
