Dumb tailgate question - Slam it or open the handle?
alvald83
Post by alvald83 »
I tried lubricating the tailgate mechanism but cant get it to close easily. It will close easy if i pull the handle out, but i remember in the old days just slamming the tailgates shut. Nothing seems to be bent but the actual handle is a bit rusty. I picked up a good looking handle at the local wrecking yard but had such trouble getting the little clips off, im not looking forward to replacing it. thanks for your help. Al
Ranchero50
Re: Dumb tailgate question - Slam it or open the handle?
Post by Ranchero50 »
I always open the handle.
Jamie
69rangerf100
Post by 69rangerf100 »
:yt:
David
Florian
Post by Florian »
:yt: x2
1971 Ford F100, 302cui, 3 on the tree
george worley
Post by george worley »
:yt:
bluef250
Post by bluef250 »
:yt:
Why fight it?
i have had both types of tailgates. some you just slam others most others. you use the handle to close it. i think it is a adjustment or wear to the latches that causes the handle having to be used.
70_F100
Post by 70_F100 »
If you keep everything lubed up, you can close it pretty easy without opening the handle.
I've found that mine works fine unless I let the latch mechanisms get dry.
That's not an oil leak :nono: That's SWEAT from all that HORSEPOWER!! :thup:
hazelnut
Post by hazelnut »
If i try to close mine without useing the handle all i get is a bang when it stops at the latches, but if i use the handle its as smooth as a onion.
flyboy2610
Post by flyboy2610 »
Caseys71
Post by Caseys71 »
Like most other guys here I open the handle before shutting my tail-gate as well, it is lubricated good enough to close without doing it but why slam it if you don't have too :? :lol:.
Casey
Sparx Macgyver
Post by Sparx Macgyver »
I open the handle. It won't close otherwise. It also sticks out a bit on the driverside. But only when it's closed.
[72|F100|SC|Stock]
ok68crewcab
Post by ok68crewcab »
I always open the handle, less stress on all the parts including me. I cringe when someone tries to close it by slamming it.
2 Blessed 2 Be Stressed
1967AceStroker
Post by 1967AceStroker »
I always have opened the handle. I even open the handle on my newer truck.
My Project Thread (Not updated in years.)
1967 F-100, Shortbed, 351W - 72mm Single Turbo - Megasquirt MS3x Engine Management, Tremec TKO 500, Ford 9" - Strange Nodular Center Section - Strange 35 Spline Axles - Strange Full Spool - Caltracs - DJM Drop Kit, Crown Vic IFS Swapped - 2 Coils Cut, Power Steering, Power 4 Wheel Disc Brakes, Paint - Kona Blue
Big Blue 72
Post by Big Blue 72 »
