Is the 67 bendix power booster any good?
I have read about all the 67 power booster swap issues, so is it a good idea to use a 1967 Bendix Hydrovac Power Booster, or are the more modern boosters the way to go?
re: Is the 67 bendix power booster any good?
The '67 boosters are a bit more expensive and cumbersome. If you already have one installed and it's working fine, I wouldn't replace it with the later style. However, if it's going bad, or you're adding power brakes for the first time, I'd suggest just getting the newer style (along with a '68-up brake pedal assembly to match).
I dont have power brakes now so was hoping to add them (to the existing drums) I saw a bendix PB on ebay but am not sure if it would work. If get a 68+ brake peddle can i just then go to an auto parts store and get a booster? Do i need any vac lines to the carb?
- 68F250
fordloaf, can you link us to that ebay auction?
Barry
I would get the '68-up brake pedal assembly (the bracket and everything) and bolt it into your truck, then go to the parts store and get yourself the booster. You'll also need to get a check valve (I'm not sure if the booster will come with one or not probably not) that looks like this:
Also, the replacement boosters don't come with mounting brackets, so you'll have to hit a salvage yard for those.
You will need to hook up a vacuum line between the intake manifold and the check valve. The hose is clamped up out of the way to the firewall and then connects to the intake manifold. Normally there's a 'T' mounted at the back of the manifold, or at least a plug where one should be.
Re: re: Is the 67 bendix power booster any good?
[quote="68F250"]fordloaf, can you link us to that ebay auction?[/quote]
It is item 4570366713, now that i look at it, maybe it is not for a F series truck??? Hmm.
That setup is for the heavy-duty trucks, it won't work for the F100-F350s.
